Sat Sep 15, 2012Total posts : 2
Kinley Tshering
Kinley Tshering
Topic: Hi all I am constructing a residential building and I have completed the structu
Hi all I am constructing a residential building and I have completed the structural part and now I am preparing to erect walls and now I am thinking to use solid concrete bricks, which I would like to seek advice, as I have seen some of the buildings constructed with this bricks and observed cracks in between columns and the concrete bricks even after a good plastering.Most of the crack are in the corners. so please advice as I also wanted to use this bricks due to less in cost compared to red bricksRegardsKinley Tshering
Mon Sep 17, 2012Post  #1
piyush
piyush
Post subject: adv
sir,
for your kind information that the red clay bricks are little bit costlier than cement concrete brick/blocks but due less weight and more morter joints the chances of cracks in the infill panels are much less than other concrete blocks. so use the clay brick which also serve the purpose of heat reduction in internal parts of building.
the cracks at joints of column/beam with masonry or common for all type of bricks whether it is of clay or cement.
to avoid the crack at the joints of masonry and rcc frame beam/column etc use GI OR MS chicken mesh at the joints before plaster the all surfaces.
i hope that this advice will usefull to you and others
thanks
Er. P.A. lalwani
Mon Sep 17, 2012Post  #2
piyush
piyush
please reply if possible at my mail id
purshottam.lalwani36@rediffmail.com
pldesignhome1969@gmail.com
thanks
1908
Is real estate broker having good career
Last answer on 5/17/2021 7:02:40 AM. by S L Gupta (Civil Engg). Forum started by Satvinder kaur
2474
1340
3502
2224
New Construction
1846
Hi Suresh, I am not able to see complete picture.. can you pls reupload it..Moh
Last answer on 12/26/2011 7:23:00 PM. by Amit Hasija. Forum started by arajamohan
2125
Want to build 30*35 residential building suggest me some plans
Last answer on 1/5/2022 12:37:08 AM. by sweety. Forum started by ihsan
2305
1809
what re these in gharexpert estimates
Last answer on 12/17/2015 2:57:41 PM. by JAI PRAKASH. Forum started by sushantsah
3433
3608
18435
1556
6099
What is construction cost
2690
DOORS
2558
Bye Law
3644
Last answer on 10/11/2020 7:16:16 AM. by Amit Hasija. Forum started by disha gupta
3451
how to line out work to residential building
Last answer on 7/4/2020 2:18:55 AM. by S L Gupta (Civil Engg). Forum started by patil kiran
15
17
Compact
Compact Hi-Tech Kitchen
Orientation
Orientation of Building
Basic
Basic home security tips
Cupola Proportions
Tips for cupola proportions
