Wed Aug 29, 2018Total posts : 1
Ravi sharma
Ravi sharma
Topic: Hi sir,what is minimum distance should follow sump and pillar footing. can be su
Hi sir,what is minimum distance should follow sump and pillar footing. can be sump depth more than column footing?
Wed Sep 05, 2018Post  #1
          Sump depth should not more than column footing depth and it should be minimum 5' from column footing.
pillar size in distacce
4586
Reagarding Coulmn Pillar
Last answer on 9/29/2015 11:01:46 AM. by S L Gupta (Civil Engg). Forum started by Amit Kumar
12461
First floor construction
1778
4389
3739
Hi Now I am in the construction, my kitchen is 10 feet x 10 feet, your expert is
Last answer on 8/1/2018 11:35:24 PM. by S L Gupta (Civil Engg). Forum started by kannaa
42123
3792
2948
Number and position of pillars
Last answer on 7/3/2020 10:41:58 PM. by Ananda. Forum started by Ananda
3342
Column footing size
Last answer on 7/4/2020 2:00:01 AM. by S L Gupta (Civil Engg). Forum started by Pooja
6548
3607
18435
2151
house plan for 39 feet road side and 32 feet depth for noth facing
Last answer on 1/2/2015 11:13:55 AM. by seema tyagi. Forum started by ravi kiran
2971
duration of constucting home
3237
2935
Right price or not .. Kindly advise
Last answer on 7/3/2020 9:28:23 PM. by S L Gupta (Civil Engg). Forum started by everfor
5811
2329
i am constructed the circular wall of 30 feet dia.,30 feet height
Last answer on 1/6/2022 10:11:07 AM. by S L Gupta (Civil Engg). Forum started by shivprasad
Brick Pillar
Compact
Compact Hi-Tech Kitchen
Vastu for Water Tank
Basic
Basic home security tips
What is acre
Designing
Designing a Foundation
