Mon Jun 20, 2011 | Total posts : 4 |
| Topic: Hi ...Estimation of per sqft construction of a house on 900 sqft in Bangalore..Uttrahalliarea
Am planning to build a house G + 1 ..
Pland are like Ground Floor will have a car parking , 1 hall, 1 kitchen, 1 dining space, 1 toilet and 1 bed room
and 1st florr will have , 2 bed room each with attached toilet , a balcony, 1 pooja ghar,
1 more requirement is I need a small study rum as well..not sure where to fit this ?? in G+1 plan.
Can anyone suggest me if the above plan is nice and can be managed ..What I mean is that can be accomated and aswell shouldn't look or make us feeel congested?
And the last but the most important thing is what could be the estimated cost in construction
Mon Jun 20, 2011 | Post #1 | Gunjan Utraja
Join date: Dec 2007 | Post subject: Detailed construction cost estimate service fro...
Detailed construction cost estimate service from GharExpert.com:
A detailed cost estimate
is a step by step calculation of the material and labor required to
complete a construction project. This document is prepared after analyzing
the architectural plan of the building and has all details about the
cost and material involved. For example, it will give you the exact
quantity of cement bags, bricks, sand, steel and other raw material required
and the prices in your area.
The detailed estimate cost is:
Up to 2000 sq.ft area= Rs.2.50 per sq.ft.
From 2001 to 5000 sq.ft area= Rs.2.00 per sq.ft.
From 5001 to 10000 sq.ft area= Rs.1.50 per sq.ft.
Above 10000 sq.ft area= Rs.1.00 per sq.ft.
Using this document one can save upto 10% of the construction cost which can be
a saving of Rs. 50 to Rs.100 per square feet.
Click on the link given
below to view the sample estimate:
ยท
http://www.gharexpert.com/include/sample_estimate.pdf
Client Testimonial Albert Asirvatham " Thank you very much for provided the cost estimation and Very useful to finalise the contractor"
Tue Jun 21, 2011 | Post #2 | P. Panchal
hi u can roughly calculate it by 800 rs. per sqft
Tue Jun 21, 2011 | Post #3 | ramu771964
Join date: Apr 2010 | Post subject: House Construction cost
Dear Arindam,
Your immagination to have G+1 with Hall, Dining, 1 Bed room +Toilet plus Kitchen in G.Floor, and Two bed + Toilets plus Puja room with Balcony is good and ideal. Staircase you can accomodate inside the house.
It comes to around Rs.1000/- to Rs.1100/- per SFT. for construction for House using Normal wood doors / windows ,Vertified Tile flooring with one coat of paint.
Other works like false ceiling, wooden cubboards, etc.. finishing works will come additio | |
Thu Aug 11, 2011 | Post #4 | SUSHEEL
Join date: May 2010 | THE GROUND FLOOR COST UPTO RS 900/SQ.FT AND FIRST FLOOR COST RS 1150/- PER SQ.FT. INCL. WOODEN WORK AND EXCLUDING ANY TYPE OF GOV. CONST. CHARGES IF ANY.
Layout and House Plans-Construction Questions (39) | |
Articles that might interest you! | | Gharexpert can save you money during construction Do you know almost all individual home construction projects in India take more money to complete than what people ori.. | | Vastu for Construction of House If you have bought a land/plot which is not as per vastu, you can amend it by making proper construction and using pro.. | | Compact Hi-Tech Kitchen We are living in sci-fi (Scientific) world where we notice all high tech gadgets around us like mobile, palm tops etc... | | Why an Architect should be hired? We recommend that an architect should be appointed for the construction of any house as the professional help would be.. | | List of construction activities in sequence Before going for any construction do you know what the sequence of construction activities is? Here is a list of const.. | | Home Construction Safety There are several home construction safety tips which can be applied during construction of the house. This article wi.. | | Stair construction-Things to remember Stair construction needs major consideration while you are either building a new home or just doing any renovation. Th.. | | Are you constructing a cupboard, Learn the difference between wood-only and wood-brick cupboards Cupboards construction using different materials: Brick and Wooden Cupboards, Just Wooden Cupboards, Mesh Cement and W.. | | Basic home security tips We all know about them but we still fail to follow these safety tips. Here is a ready checklist of the do-es and don't.. | | Planning a House Once the architect has given his design options, it becomes necessary to select one and start working on it. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
