Hi. I am constructing the first floor of my house. I will be laying floor in the
Thu Apr 07, 2016Total posts : 1
JP Sachdev
JP Sachdev
Topic: Hi. I am constructing the first floor of my house. I will be laying floor in the
Hi. I am constructing the first floor of my house. I will be laying floor in the next few days. The usual practice is to first install a layer of of broken bricks (rodi) before putting on tiles or marble. Because it is the first floor so already have concrete slab ( that is roof) on which floor has to be laid on, I am not able to understand the purpose of putting a layer of 'rodi'. Won't it add on an extra layer of unnecessary weight on the roof. Kindly help.
Fri Apr 08, 2016Post  #1
Dear JP
        Laying lean concrete i.e. (Rodi) or brick ballast serves two purpose.
1. To provide rough surface for floor which is necessary for proper binding of floor material.
2. To provide space for any types of pipe or wire etc.
3. To maintain slope.
3326
5812
2380
Spiral staircase from first ground floor to first floor
Last answer on 3/4/2015 12:37:11 PM. by satish. Forum started by satish
3134
false ceiling
2224
New Construction
2972
duration of constucting home
2529
duct size for and kitchen
Last answer on 7/3/2020 11:52:01 PM. by seema tyagi. Forum started by Yogender Singh
5124
2051
I am planning to construct first floor on the existing house and like to know co
Last answer on 7/17/2013 11:49:00 AM. by S L Gupta (Civil Engg). Forum started by MANJUNATH
3238
2390
6147
3230
4134
estimate cost for 1800sfft building construction
Last answer on 3/5/2014 10:59:21 AM. by S L Gupta (Civil Engg). Forum started by Satyanarayana Seeram
2915
construction suggestion needed
Last answer on 12/21/2011 9:40:34 AM. by ravi at Dalmia. Forum started by rajan
1649
Design Layout for Shops and Flats
Last answer on 5/10/2016 11:43:26 AM. by S L Gupta (Civil Engg). Forum started by Amir Rehman
2540
Last answer on 7/4/2020 2:31:17 AM. by S L Gupta (Civil Engg). Forum started by ramaiyacp
3889
23
27
Compact
Compact Hi-Tech Kitchen
Guideline for laying DPC
Terrazzo
