Hi,I have purchased a Ground Floor house with 222 yards and which is constructed
Sat Apr 19, 2014Total posts : 1
nagaraju
nagaraju
Topic: Hi,I have purchased a Ground Floor house with 222 yards and which is constructed
Hi,I have purchased a Ground Floor house with 222 yards and which is constructed on 2003.I want to construct 1st floor on this building but columns rods are not available and those rods were cut till slab level.Can u pls suggest how can I build 1st Floor and is it safe 2 construct 1st floor on this existing building
Mon Apr 21, 2014Post  #1
Dear Nagaraju
        It is better if you consult any structural engineer / civil engineer form your city , who will guide you after inspecting the site.
In my opinion if columns steel is not available than it is very difficult to start column for this you have to dismantle the old column at top but better to get consultation.
dear sir, iam purchased plot 222 sq.yards ,south face ,send u r contact details,
Last answer on 2/3/2021 8:51:26 AM. by JAI PRAKASH. Forum started by kishore
1759
can v construct the 1st floor on 10 yrs old building but the coloumn rods are cut till slab level
Last answer on 4/21/2014 3:52:19 PM. by S L Gupta (Civil Engg). Forum started by nagaraju
1322
3227
how many floors can be constructed in a 242 sq yards plot in vikas puri?is stilt
Last answer on 4/1/2021 12:37:58 AM. by seema tyagi. Forum started by DR GOEL
9946
1583
How much Marole required
2455
2525
Last answer on 7/4/2020 2:31:17 AM. by S L Gupta (Civil Engg). Forum started by ramaiyacp
3210
1463
for best house plan according to vasthu
Last answer on 6/10/2016 5:59:00 PM. by raj. Forum started by raj
2210
New Construction
2589
5739
5114
2291
3456
2429
I need 22x55 137 yards south facing first floor house plan
Last answer on 7/4/2019 1:15:58 AM. by AR. HIMANSHU PHOGAT. Forum started by shyamsunderreddy
3495
3603
built up area vs land area
Last answer on 7/13/2020 10:50:09 PM. by S L Gupta (Civil Engg). Forum started by cgvmp
206
65
24
21
22
24
24
22
22
24
21
21
18
26
18
23
23
Compact
Compact Hi-Tech Kitchen
Preliminary
Buying tips for Brick Blast
Buying
Buying tips for Cement
Tips to remember while purchasing a garden bench.
Landscaping
Landscaping for a Small Space
