Home -> Forums -> Construction -> Start Construction -> Hollow Brick Wall thickness for RCC roof
Mon Aug 10, 2015Total posts : 0
gpeter
gpeter
Topic: Hollow Brick Wall thickness for RCC roof
Hello Friends,
I am planning to construct a simple cottage in my backyard.  Most of the work will be done by me.  Your advice is most welcome as I am a new bee in this field.
Cottage size:
        Length = 13m (3 parallel walls of 13m each).
        Width  = 8m (2 side walls 8m each)
        All walls are double brick(hollow) (23cm) wide.
       The distance between 3 parallel walls is 3.6m
       The 13m long centre wall will be manuplated  by beams create rooms.
 Please seen rough sketch in the attached file.
Could you please advise me if
1. the hollow clay brick (grade 1) walls of width 23cm is enough to support the RCC slab.
2.  As the length is long (13m) do I need to include pillars and provide support beams.
Any opinion will be most appreciated.
Gerard
Attachments: MyHobbtCotage.doc on Mon Aug 10, 2015,&n
2153
3980
Roof leakage
2460
Requirement of wall wall thickness
Last answer on 6/18/2013 8:01:29 PM. by pendli. Forum started by pendli
3838
Roof Beam
1702
1875
4133
2054
11105
2616
Exterior Walls
1480
2808
2720
1172
2609
roof thickness
Last answer on 2/26/2022 9:17:15 AM. by S L Gupta (Civil Engg). Forum started by gautam kumar
9198
3088
9556
Last answer on 10/17/2016 1:19:41 PM. by Vishal Thakur. Forum started by Vishal Thakur
3312
2236
2717
2313
2061
