Home -> Forums -> Construction -> Plumbing -> Hot Water Tank
Hot Water Tank
Tue Oct 07, 2008Total posts : 2
Kanhaiya
Kanhaiya
Topic: Hot Water Tank
I need some information on hot water tank. If someone can write an article that would be great too.
I have 4 master bedroom 2 floor house. It's more of vaction type house. Won't be used very frequently.
The info  I need is Size Capacity Spec and Brand of Tank.
Thank You.
Tue Oct 14, 2008Post  #1
S.Krishnan
S.Krishnan
Hot water storage tank uses two sources of energy which becomes more expensive. This type of system constantly heats the water. When we are not using the water, some heat will be lost due to environment and level or quality of insulation. This means more electricity or gas is used to reheat the water; which will be costly, unnecessary, misuse of energy sources.
An alternative arrangement for hot water storage tank is the tank less water heater. It supplies hot water on demand. Key component of this system is heat exchanger. The heat exchanger is powered by traditional energy sources like electricity or gas. But it is only activated when hot water is needed. So this method is economical.   As per your query, you are living in the house during vacation. It will be better to use tank less water heater.    For supply of water to the tank less water heater you should provide polythene storage tank with capacity of 2000 liters. Polythene storage tanks are most economical, light in weight, stronger, easy to handle and install. They are impact resistance and no need for special bedding or foundation.
Sat Jan 09, 2021Post  #2
Fox
Fox
I like hot water storage tank is the tank less water heater.
5054
2374
water tank
2482
1727
1933
2185
3119
7232
2 lakh litre water tank
1844
6270
Water Tank Quality
1886
water tank motor capacity
2387
2234
2958
Last answer on 9/1/2015 2:51:50 AM. by JAI PRAKASH. Forum started by sher singh daulta
2022
2333
2219
water supply
1773
2058
6270
Water Tank Quality
2914
Sand in Water
3379
Diverters for Bathroom
2561
2144
40515
2083
GI pipe Vs CPVC pipeline
2930
1754
2079
Toilets
1987
Wall mounted cummod vs normal
5054
2774
2387
1854
3074
Swimming pool
2541
water softner
2681
commode type and flush type
4192
to shut off water to house
Vastu for Water Tank
Preventive
Relax
Relax yourself with Jacuzzi Bath
Relax or rehydrate your body with Jacuzzi bath. Jacuzzi bath is amazing stress reliever and best luxury experience to ..
Reasons of dampness
60
60 Tips to Save Water
Water for Construction
