Home -> Forums -> Construction -> Layout and House Plans -> House Plan
Mon Jan 21, 2013Total posts : 3
sarita.angadi
sarita.angadi
Topic: House Plan
Dear Sir/Madam,
Iam planning to build an east facing house on the first floor with length 26 feet and heght 28 feet (carpet area). Can you please suggest a plan as per vaastu with a living room, pooja room, kitchen with store room, master bedroom with attached bath, childrens room & common bath.
Thu Mar 30, 2017Post  #1
Saurav anand
Saurav anand
Post subject: contact @ 9406526828 for good floor plan
hi sir / madam ,
i am saurav anand .  i have very good experience in building designs  plz see my work
find attached file.
SAURAV ANAND
Civil engineer / 3d visualizer
940652682
Attachments: 3d floor plan 25' x 25'.jpg Thu Mar 30, 2017,
FINAL .jpg Thu Mar 30, 2017,&n
Fri Mar 31, 2017Post  #2
Thu May 14, 2020Post  #3
A house plan is a set of construction or working drawings that define all the construction specifications of a residential house such as the dimensions, materials, layouts, installation methods and techniques.
Site plans are drawn to show the location of a home on the property in its context. It is an overhead view of the construction site and the home as it sits in reference to the boundaries of the lot. Site plans should outline location of utility services, setback requirements, easements, location of driveways and walkways, and sometimes even topographical data that specifies the slope of the terrain.
A floor plan is an overhead view of the completed house. On the plan, you will see parallel lines that scale at whatever width the walls are required to be. Dimensions are usually drawn between the walls to specify room sizes and wall lengths. Floor plans will also indicate rooms, all the doors and windows and any built-in elements, such as plumbing fixtures, cabinets, water heaters, furnaces, etc. Floor plans will include notes to specify finishes, construction methods, or symbols for electrical items.
Elevations are a non-perspective view of the home. These are drawn to scale so that measurements can be taken for any aspect necessary. Plans include front, rear and both side elevations. The elevations specify ridge heights, the positioning of the final fall of the land, exterior finishes, roof pitches and other details that are necessary to give the home its exterior architectural styling.
A section cuts through the dwelling and the location of this 'cut through' is noted on the floor plan. It describes how the building will be constructed and discusses how the internal finishes are to look. Sections are used because they explain certain conditions in more detail. These conditions may include ceiling height, ceiling type (flat or vault), and window and door dimensions.
Layout and House Plans-Construction Questions (40)
2379
1944
Hi i want 18*70 house plan.. Pls suggest me and make of house plan of 18*70
Last answer on 7/3/2020 11:48:09 PM. by S L Gupta (Civil Engg). Forum started by HARSH
1898
15654
5174
1567
6809
Best elevation deisgns for west facing two floor house with 30 x 45 feet
Last answer on 4/22/2021 2:52:43 AM. by Michaell. Forum started by K.Ashok Kumar
2227
i have 130 sq yard house with 23 by 51 fit give me house plan
Last answer on 2/7/2016 10:38:50 PM. by JAI PRAKASH. Forum started by gulam yazdani
2238
Sir I want east facing 21.3×48 house plan design's
Last answer on 3/5/2016 10:38:30 PM. by JAI PRAKASH. Forum started by Venkat
2418
i want to house plan for 1 floor size 17 feet width and 39 feet lenth
Last answer on 5/29/2017 5:57:46 PM. by Saurav anand. Forum started by rajusapra
1832
i want house plan of that pic
Last answer on 4/19/2016 10:16:55 AM. by S L Gupta (Civil Engg). Forum started by Arjun singh
2155
size of house planned 35 ft front and 45 ft depth with 1st floor
Last answer on 5/12/2016 6:07:13 PM. by Lingraj Halli. Forum started by ROHIT KUMAR
2488
east facing residential house plan for double bed room with vastu required
Last answer on 5/5/2016 2:14:48 PM. by Anany goel. Forum started by SatheeshB
2158
Can u send me 22/60ft house plan of north face
Last answer on 4/28/2019 10:57:17 PM. by Beenu Phogat. Forum started by spriti
1683
Last answer on 11/15/2016 11:30:27 AM. by Beenu Phogat. Forum started by Heeralal Chowdri
2364
Home plan for 18 by 90 feet
Last answer on 10/1/2021 9:44:32 PM. Forum started by SHYAM
1801
Last answer on 11/1/2016 12:11:47 PM. by Beenu Phogat. Forum started by ASV Sarma
1680
Required House Plan for 15x40 Site
Last answer on 10/24/2016 11:57:46 AM. by Beenu Phogat. Forum started by Anand
2448
I need 22x55 137 yards south facing first floor house plan
Last answer on 7/4/2019 1:15:58 AM. by AR. HIMANSHU PHOGAT. Forum started by shyamsunderreddy
2275
I need 30x50 feet east facing ground floor house plan with 3 bedrooms
Last answer on 7/11/2016 1:48:57 PM. by Amrit Bhagat. Forum started by ananddv3
2696
2929
2193
2191
2804
4525
1896
2289
2276
2775
3468
2363
1976
2248
3600
2331
2096
2796
1554
2122
Painting
Environmentally
