Home -> Forums -> Construction -> Layout and House Plans -> House Plan
Fri Feb 28, 2014Total posts : 1
raghu
raghu
Topic: House Plan
can  you pleas send me a House Plan for 25 x 40 site .
rooparaghunz@yahoo.co.nz
Mon Mar 03, 2014Post  #1
Dear Raghu
2379
1945
Hi i want 18*70 house plan.. Pls suggest me and make of house plan of 18*70
Last answer on 7/3/2020 11:48:09 PM. by S L Gupta (Civil Engg). Forum started by HARSH
1901
15659
5174
1568
6811
Best elevation deisgns for west facing two floor house with 30 x 45 feet
Last answer on 4/22/2021 2:52:43 AM. by Michaell. Forum started by K.Ashok Kumar
2227
i have 130 sq yard house with 23 by 51 fit give me house plan
Last answer on 2/7/2016 10:38:50 PM. by JAI PRAKASH. Forum started by gulam yazdani
2238
Sir I want east facing 21.3×48 house plan design's
Last answer on 3/5/2016 10:38:30 PM. by JAI PRAKASH. Forum started by Venkat
2419
i want to house plan for 1 floor size 17 feet width and 39 feet lenth
Last answer on 5/29/2017 5:57:46 PM. by Saurav anand. Forum started by rajusapra
1835
i want house plan of that pic
Last answer on 4/19/2016 10:16:55 AM. by S L Gupta (Civil Engg). Forum started by Arjun singh
2155
size of house planned 35 ft front and 45 ft depth with 1st floor
Last answer on 5/12/2016 6:07:13 PM. by Lingraj Halli. Forum started by ROHIT KUMAR
2488
east facing residential house plan for double bed room with vastu required
Last answer on 5/5/2016 2:14:48 PM. by Anany goel. Forum started by SatheeshB
2159
Can u send me 22/60ft house plan of north face
Last answer on 4/28/2019 10:57:17 PM. by Beenu Phogat. Forum started by spriti
1683
Last answer on 11/15/2016 11:30:27 AM. by Beenu Phogat. Forum started by Heeralal Chowdri
2364
Home plan for 18 by 90 feet
Last answer on 10/1/2021 9:44:32 PM. Forum started by SHYAM
1803
Last answer on 11/1/2016 12:11:47 PM. by Beenu Phogat. Forum started by ASV Sarma
1680
Required House Plan for 15x40 Site
Last answer on 10/24/2016 11:57:46 AM. by Beenu Phogat. Forum started by Anand
2448
I need 22x55 137 yards south facing first floor house plan
Last answer on 7/4/2019 1:15:58 AM. by AR. HIMANSHU PHOGAT. Forum started by shyamsunderreddy
2276
I need 30x50 feet east facing ground floor house plan with 3 bedrooms
Last answer on 7/11/2016 1:48:57 PM. by Amrit Bhagat. Forum started by ananddv3
2697
2929
2194
2192
4526
1897
2291
2277
2777
3470
2363
1976
2249
3601
2332
2097
2797
1556
2123
Painting
Environmentally
Copyright 2007- 2025 GharExpert.com All rights reserved.
