Home -> Forums -> Construction -> Start Construction -> House construction on 30ft X57ft
Thu Dec 19, 2013Total posts : 8
Shan
Shan
Topic: House construction on 30ft X57ft
Hello experts,
I am planning to build a house for rental purpose on my 30ft x 57ft (east facing) plot).
My question is, is it possible to build a 2 units of 2 BHK each/ floor?
Fri Dec 20, 2013Post  #1
Dear Shan
Fri Dec 20, 2013Post  #2
Shan
Shan
Before purchasing a plan, I wanted to know if it is possible to build 2 units of 2 BHK each.on 30ft X 57ft Also I am not able to find any such plan from your website.
Sat Dec 21, 2013Post  #3
Post subject: is it possible to build 2 units of 2 BHK each....
Hello..! Shan ..It is not possible to construct 2 units of 2 BHK on each floor according to rules.. you should  go for 1BHK unit or 2 Duplex of 2 BHK  or  single 2BHK Unit on each floor .... regards
Tue Dec 24, 2013Post  #4
kamal
kamal
Yes u can...
Tue Dec 24, 2013Post  #5
kamal
kamal
Yes u cn
See attach pic..plot size 35x45...
Attachments: IMG_20131211_123630.jpg Tue Dec 24, 2013,&n
Thu Jan 09, 2014Post  #6
Shan
Shan
Navneet kamal Thankyou for the reply.
Kamal, as Navneet says it may not be possible if go as per Govt rules (by respection the offset and floor area regulations)
Sat Jan 11, 2014Post  #7
Raju V K
Raju V K
You did not said about the location   of the    plot. Local building rules have variations in set offs, which will limit   the size of rooms.
Mon Jan 13, 2014Post  #8
Shan
Shan
Dear Raju V K, the plot is located in Bangalore
2041
house layout
Last answer on 1/3/2017 1:20:31 PM. by S L Gupta (Civil Engg). Forum started by mahesh shukla
1779
Need a house layout plan for 450 sq feet land - size - 15ft X 30ft. pls help
Last answer on 10/20/2016 1:50:26 PM. by Beenu Phogat. Forum started by Aditya
4819
Last answer on 5/13/2016 1:11:58 PM. by kushagra khare. Forum started by ankur gupta
1551
front 30ft back 29ft.lengh 76
Last answer on 2/25/2015 9:12:36 AM. by seema tyagi. Forum started by raman kumar
3450
3080
3857
4033
2561
house construction plans for 20x30 site
Last answer on 7/4/2020 2:28:10 AM. by Amrit Bhagat. Forum started by ramu
1585
Checklists for flooring
Last answer on 4/4/2015 7:09:35 PM. by JAI PRAKASH. Forum started by MUTHU
1794
Last answer on 1/27/2016 12:04:33 PM. by S L Gupta (Civil Engg). Forum started by A Ghosh
2009
2606
COLUMN nd LOAD BEARING
2286
1765
1269
himy plot size is 30ft by 70 ft.north east corner.planning to build g 2 building
Last answer on 11/14/2017 11:40:30 PM. by S L Gupta (Civil Engg). Forum started by sridhar
2064
construction of new house on a two side open plot
Last answer on 5/2/2013 1:08:19 PM. by ashish. Forum started by ashish
1672
Dear sir my house construction is going very well but my house front side EB pow
Last answer on 10/12/2015 10:30:39 AM. by S L Gupta (Civil Engg). Forum started by balamurugan
2232
Sir, I want to construct a home in my plot measuring 1200 Sq feet(South-west cor
Last answer on 1/1/2013 6:28:28 PM. by Pavan. Forum started by santosh mahatme
2451
3274
3285
4429
3975
2198
2699
4212
5169
2378
2294
1996
2447
2114
3195
2047
12514
2164
2012
2727
Why
