I HAVE MY HOUSE ON LAND OF 60FX90FT. FRONT IF OF 60 FT ON NORTH DIRECTION. I MA
Wed Mar 17, 2010Total posts : 1
MANISH JOSHI
MANISH JOSHI
Topic: I HAVE MY HOUSE ON LAND OF 60FX90FT. FRONT IF OF 60 FT ON NORTH DIRECTION. I MA
I HAVE MY HOUSE ON LAND OF 60FX90FT. FRONT IF OF 60 FT ON NORTH DIRECTION. I MANT TO BUILDUP 1ST FLOOR. NO PLACE TO CREATE STAIRS ON EAST SIDE N LEFT WITH WEST SIDE OF 15 FT N FRONT WHICH IS OF NORTH AROUND 30 FT. SHOULD STAIRS CAN BE IN WEST TOWARDS SOUTH IN CLOCKWISE.
Wed Mar 17, 2010Post  #1
Ajit Tareeka
Ajit Tareeka
Post subject: GharExpert article is available on staircase vas...
Vastu verifies to locate staircase of the building in the South or West direction. Staircase is a heavy structure; hence it should be located in negative zones like the South or the West. The staircase in northern or eastern part of house may give adverse effects. The stairs should rise from the East to West or from the North to South. The staircase should not be in the center of the house. Avoid staircase in northeast direction also.
Here are some Do’s and Don’ts for functional staircase.
DO’S
  • Make staircase of the house in southern or western part of the house as these directions are heavy.
  • Build staircase in southeast in east, northwest in north, southwest in west and southwest in south if the staircase is external.
  • Arise the stairs from the East to West or from the North to South and a turn can be taken to any other side due to paucity of space.
  • Make the number of stairs odd. It should not end with zero. The number of risers should be such odd numbers that if divided by 3, the remainder is always 2.
  • Paint staircase in light colors. Avoid red and black color.
  • Repair broken stairs immediately otherwise it may cause accidents or mental tension due to clashes.
DON’TS
  • Avoid staircase in northeast of the house and in center of the house as it will cause loss of wealth. The staircase in any other corner reduces loss.
  • Do not make staircase circular as it may cause ill effects on health.
  • Do not build any room such as kitchen, bathroom and ‘Pooja’ room under staircase. However it can be used for storage.
  • Do not use common staircase for going upstairs and basement.
I am in need of lay out plan foo house.land area 600 sq mtrs.60 ft x 90 ft.
Last answer on 8/3/2012 2:05:24 PM. by Ar. Manoj Ralen. Forum started by viqar idris
1334
1645
Sr I wont to bild 600sq ft on piled house bicose my land is river front 8to10ft
Last answer on 10/11/2015 8:04:12 PM. by JAI PRAKASH. Forum started by ismail
4480
1880
2147
size of house planned 35 ft front and 45 ft depth with 1st floor
Last answer on 5/12/2016 6:07:13 PM. by Lingraj Halli. Forum started by ROHIT KUMAR
2093
My House is north facing please tell which is best direction for installing wate
Last answer on 11/19/2012 11:30:26 AM. by Amit Hasija. Forum started by Anuj Anand
2204
Construction plan
Last answer on 12/20/2013 2:54:59 PM. by S L Gupta (Civil Engg). Forum started by Dr Ranjan Biswas
3100
my house is not having North-East corner
Last answer on 1/16/2022 10:09:46 AM. by sabina vanjani. Forum started by yogesh
2442
Last answer on 5/3/2016 12:15:23 AM. by JAI PRAKASH. Forum started by Anuj
12148
41*43 sqr ft north face only850sq ft small budget house
Last answer on 11/23/2016 12:00:28 PM. by Beenu Phogat. Forum started by kannan
2933
Hello Every 1I want house plan for 1350 sq ft area 22.5 * 60 ft.Double storyGrou
Last answer on 2/18/2014 11:28:50 AM. by S L Gupta (Civil Engg). Forum started by ajmer
2811
north seeing house 900 sq.ft house models
Last answer on 4/16/2012 2:06:19 PM. by Gunjan Utraja. Forum started by usha
1389
I have 45'X33'north facing corner plot, east side having 60 feet road and north
Last answer on 12/31/2016 1:33:22 PM. by S L Gupta (Civil Engg). Forum started by BALRAM TINGHI
2150
Map for Gaumukhi Plot
Last answer on 7/4/2020 2:28:56 AM. Forum started by akshay
2652
map for gaumukhi plot
Last answer on 7/4/2020 2:28:35 AM. Forum started by akshay
1456
i m having a small polt of 60 ft from north to south and 30 ft from east to west
Last answer on 11/17/2015 9:07:29 PM. Forum started by Munna Thakur
2024
I have 20*70 ft north facing house please give me vastu suggest
Last answer on 10/6/2015 8:20:03 PM. by JAI PRAKASH. Forum started by shilpa
31352
40*60
Last answer on 7/3/2020 10:18:41 PM. by seema tyagi. Forum started by T RANJITH KUMAR
What is acre
60
60 Tips to Save Water
Hardwood
Hardwood door
Hardwood
Hardwood window
Landscaping
Landscaping for a Small Space
