Home -> Forums -> Construction -> Layout and House Plans -> I WANT LAYOUT FOR A PLOT OF 31 WIDTH & 68 LENGTH WITH ROAD BOTH IN NORTH AND SOU
Thu Feb 27, 2014Total posts : 2
VIVEK PRAKASH
VIVEK PRAKASH
Topic: I WANT LAYOUT FOR A PLOT OF 31 WIDTH & 68 LENGTH WITH ROAD BOTH IN NORTH AND SOU
I WANT LAYOUT FOR A PLOT OF 31 WIDTH & 68 LENGTH WITH ROAD BOTH IN NORTH AND SOUTH WITH HOUSE IN BOTH EAST & WEST.
Thu Feb 27, 2014Post  #1
Post subject: LAYOUT FOR A PLOT
Hello..! Vivek, Kindly attach your requirements also, it is very much necessary for planning accordingly.....You can select from so many plans available on Gharexpert also....Regards.
Mon Mar 03, 2014Post  #2
Dear Vivek
2302
want aplot layout
Last answer on 9/25/2014 2:50:41 PM. by seema tyagi. Forum started by vipantiwari
4519
3952
Last answer on 10/11/2020 7:21:30 AM. by S L Gupta (Civil Engg). Forum started by maruthi prasad
1945
Eastern North Road, Plot Layout HOUSE PLAN GIVE ME SIR
Last answer on 11/18/2021 10:49:57 AM. by S L Gupta (Civil Engg). Forum started by MD NIRANJAN
5576
Last answer on 11/3/2014 11:55:58 AM. by seema tyagi. Forum started by balaji
1968
plot size 31 ft X 78 ft. facing south.please provide best possible layouts
Last answer on 5/18/2015 11:50:41 AM. by seema tyagi. Forum started by ravi shanker
1658
my plot is north face, 29" width and 50"length and i want to make it in proper w
Last answer on 2/7/2016 10:39:10 PM. by JAI PRAKASH. Forum started by hirdesh
Sir i wants a layout of polt whose size is 3150 squarefeet whose front width is
Last answer on 9/26/2014 11:24:08 AM. by seema tyagi. Forum started by vipantiwari
2155
Last answer on 10/25/2021 1:47:12 AM. by JAI PRAKASH. Forum started by mgmishra
Construction House plan require for G+1 for plot size of 31* 53
Last answer on 11/29/2016 6:16:06 PM. Forum started by baji
2282
T junction north facing plot width=29 feet length=50 feet,out of the 29 feet of
Last answer on 11/16/2012 7:36:41 AM. by lakshmanmahto. Forum started by rangaprem
3305
2592
MY PLOT IS 31*40 KINDLY SEDD ME 2BEDROOM SET
Last answer on 1/23/2012 11:05:41 AM. by S L Gupta (Civil Engg). Forum started by SJPS.SINGH
1401
Sir, mmy plot size 31'*32.6' facing .south.pls.suggest vastu degine naksha.
Last answer on 6/30/2018 1:43:16 AM. by S L Gupta (Civil Engg). Forum started by Laxmikant Khandelwal
2155
Car Parking
Last answer on 4/17/2021 12:38:56 AM. by JAI PRAKASH. Forum started by Sai Pavana
1812
i have a 8marla plot length 64ft width 34 ft front street 40ft pls send me desi
Last answer on 4/18/2015 10:20:29 AM. by himanshu. Forum started by Rao Rafique Ahmad
2085
Sir I have a plot length 55.9' and width 17.4' . Can u guide me for a house map
Last answer on 4/20/2015 12:31:34 PM. by seema tyagi. Forum started by Rakesh Singh
1612
Last answer on 3/8/2017 11:11:29 AM. by S L Gupta (Civil Engg). Forum started by kirankumar
8685
i have 15 ft width & 30 ft length plot which ihas to develop tell me the plan &
Last answer on 10/28/2021 12:01:35 AM. by S L Gupta (Civil Engg). Forum started by RANJIT SINGH
2689
2923
2188
2184
2790
4519
1890
2284
2264
2765
3464
2356
1965
2240
3594
2323
2090
2792
1548
2114
