Home -> Forums -> Construction -> Brick work -> I am building a 2 storeyed building. I have a Main wall which is adjacent to a existing house.
Thu Apr 01, 2010Total posts : 2
pkarkeyan
pkarkeyan
Topic: I am building a 2 storeyed building. I have a Main wall which is adjacent to a existing house.
My wall is exactly at my border and there is a Gap available from the next plot. The Gap between my wall and the neighbour is less than 2 feet. I need to plaster that side, however the owner of next building is not willing to allow. Currently its all finished inside however the outside wall does not have plastering. I am concerned that if rain comes it will result in seepage.
Is there a solution for this.
If you can give me your mobile number I can call you. My contact number is 919866232857.
Thanks and Regards
Fri Apr 02, 2010Post  #1
PURSHOTAM BEHL
PURSHOTAM BEHL
Post subject: seepage from side wall
yes, the solution is , either you should make this gap to 4' instead of 2' so that manual plastering can be done, or otherwise , put a polythene sheet, benethe the plaster , it will do.
Thu Apr 08, 2010Post  #2
Manoj
Manoj
Post subject: Seepage from outer wall .
Quite a difficult situation .Less than 2' is quite narrow for a person to plaster  The only thing possible is to arrange a person who can put a layer of taarcol to prevent seepage
2194
Advise on Column Schedule
Last answer on 2/10/2014 1:49:50 PM. by abhishek0990. Forum started by Ajay Kostha
3501
15360
2nd floor construction
3425
2801
precautions to avoid water seepage through concrete roof
Last answer on 4/12/2014 12:54:34 PM. by viju. Forum started by viju
2473
6254
5739
What is the cost invloved in demolition of existing house in chennai.The house i
Last answer on 12/31/2020 2:19:16 AM. by Priti Arora. Forum started by Janarthanan N
5170
2363
2399
3523
I am interested to build together with you.
Last answer on 1/21/2022 4:04:29 AM. by TanyaHerrera. Forum started by Egbuta K C
4828
i am looking for a front elevation for 3 floored building
Last answer on 8/19/2012 12:09:32 AM. by Ar. Manoj Ralen. Forum started by kiran
893
My home is 3 floor, ground Plus 2 floor. But built up with 4" brick walls along
Last answer on 7/3/2020 9:43:54 PM. Forum started by Rohit Kumar
2878
3368
4041
Paint vs Wallpaper
1883
Damp
Last answer on 4/4/2015 7:00:17 PM. by JAI PRAKASH. Forum started by Jag
1780
3668
wals
3262
compound wall
21870
3279
Bedroom Wardrobes information
2244
2205
1494
1965
1732
2223
2523
1501
1907
Brick or ACC block
2024
1653
1702
4683
Brick wall on RCC slab
3928
2616
Orientation
Orientation of Building
Environmentally
Environment
Environment Friendly Houses
