Tue May 24, 2011 | Total posts : 3 |
Jay | | Join date: Jan 2011 |
| Topic: I am building flat in chennai,I looking for this kind doors do any have idea wha
I am building flat in chennai,I looking for this kind doors do any have idea what will price of these kind of doors.
Jay
The comment above talks about the image below. Click on the image to enlarge.
Wed May 25, 2011 | Post #1 | S L Gupta (Civil Engg)
This is simple design, you saw the design to any carpentor of your city who manufacture door shutter. After making the shutter. painter will finish as per your requirement. | |
Wed May 25, 2011 | Post #2 | Jay
Join date: Jan 2011 | Post subject: I am building flat in chennai do any one have a ...
what is best in term of contract? to hire exp supervicer or labor contrract which cheaper ?
Jay
mails4jay@gmail.com | |
Thu May 26, 2011 | Post #3 | S L Gupta (Civil Engg)
When planning to build your dream home it may be difficult to hire a good contractor. A successful house construction depends on good contractor. Hire a best contractor otherwise, it may end up the contract before completion of work or may result a poor construction. Before hiring a contractor, do some research about the contractor; know about his skills and experience. Before hiring a contractor you should ensure several attributes in your contractor.
If you have time than hire experienced supervisor and get work on labor rate i.e. material is to be purcased by you and this method is cheap and material will be used as per your satisfaction. |
| http://www.gharexpert.com/articles/Start-Construction-2070/Top-10-Mistakes-to-avoid-when-Hiring-a-Contractor_0.aspx
Articles that might interest you! | | Flat Roof Flat roof will be a better choice for which they want full use of building space. It appears flat with a slope for get.. | | Building New Home V/S Buying Builder Flat Buying a builder’s flat may be costlier for you rather than building a new home. But if you plan to make your own, you.. | | Types of Roofing A solid roof on building is very important for everybody living in the house. The roof should be constructed in a way .. | | 10 tips to make a small space look bigger A small space looks tidy and large if items of daily use are organized properly in it. To create a spacious feeling, p.. | | Roof Leaks - Causes and Repair Are you worried about irritating roof leaks that destroy contents of the building and have adverse effects on the heal.. | | Bricks Quality First Class Bricks must be homogeneous in texture without showing appreciable sign of efflorescence. | | Orientation of Building To get maximum ventilation and natural light in your house, make sure the building is properly oriented. Orientation o.. | | Guidelines for Ventilation in Building Proper ventilation in building ensures sound health and good living conditions. This write-up tells you some tips for .. | | Patio Design and Ideas Find Patio Design and Ideas where you can enjoy your evening after a tired day. Patio is a best place to relax and rej.. | | Bathroom Decorating Ideas Read about bathroom decorating ideas and implement in your bathroom to give some style. Browse decorating photos for b.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
