Home -> Forums -> Construction -> Dampness -> I am checking for water proofing in load bearing house (was built about 10 years
Tue Jan 17, 2012Total posts : 2
Anu Rajbanshi
Anu Rajbanshi
Topic: I am checking for water proofing in load bearing house (was built about 10 years
I am checking for water proofing in load bearing house (was built about 10 years back). One side of house was attached to hill (about 6fit of wall is touching hill)and it was built with brick wall. There is seepage on this wall. Do u have any suggestion to prevent seepage from this wall without breaking? In same house living room is below ground level. there is seepage from floor. In heavy rain about 1" water is collected in floor. What do u suggest for this floor? Hope to get reply soon thank u
Tue Jan 17, 2012Post  #1
Dear Anu
          I go through your prblem and I am in view that if there is space between your walland hill than do the plaster on the wall towords hillside and also apply waterproof mebrance on the plaster. Also see there should be no any pocket where water is collected,if any than make proper slope to drain the water
For low level room, in this case both the walls as well as the ground are liable to get damp due to capillary rise of moisture from ground.
 In such situation, it is necessary to provide damp proof of flexible material like bitumen felt over the entire area of the ground including wall thickness .This felt is also laid on vertical faces of the wall.
The horizontal & vertical surfaces should be finished smooth. This should be protected from the damages. After the treatment lay the floor topping of any type which you need.
Thu Aug 21, 2014Post  #2
ADINATH
ADINATH
dear Anu ..I would like to bring to your notice a waterproofing product I have come across recently...it supposed to work on any surface by penetration ...and requires only one time permenent application ...u can visit their site " epasia.net"
I have not used the product myself but if it indeed does what it says t can do ..then I thnk it will solve ur waterproofing problem.
Dampness-Construction Questions (35)
10048
2400
2616
COLUMN nd LOAD BEARING
3425
3941
3158
Basement waterproofing
7258
2212
4133
2256
3163
APP membrane
2333
i am facing financial problem from last 4 years
Last answer on 1/6/2022 9:08:18 PM. by Nitien Parmar. Forum started by Ramesh Babu R
2562
building permission
Last answer on 3/18/2014 1:12:06 PM. by S L Gupta (Civil Engg). Forum started by qader
1242
we built house before 10 years but stairs were on issian notrhwest side which is
Last answer on 2/21/2011 2:41:53 PM. by sabina vanjani. Forum started by SANDHYA DWIVEDI
2372
i am civil engineerimg student iam in my last yeari am preparing my final year p
Last answer on 10/12/2021 10:36:28 PM. by S L Gupta (Civil Engg). Forum started by sultan
2898
Terrace water proofing
3903
construction of 1st floor
3739
Hi Now I am in the construction, my kitchen is 10 feet x 10 feet, your expert is
Last answer on 8/1/2018 11:35:24 PM. by S L Gupta (Civil Engg). Forum started by kannaa
2115
Structure proof checking
2675
Damp Proofing
Last answer on 12/31/2020 1:53:13 AM. by Mike Perkin. Forum started by VIPIN
3491
How to solve dampness in wall
Last answer on 11/17/2016 10:58:15 AM. by Girish. Forum started by Rajan
1862
Last answer on 12/24/2015 4:06:01 AM. by JAI PRAKASH. Forum started by sushantsah
1492
Canada Goose Chilliwack Bomber much likewise
Last answer on 11/14/2015 12:37:51 AM. by JAI PRAKASH. Forum started by farofaschafer
2073
2107
2132
Walls are damp in rain
2084
1885
Damp
Last answer on 4/4/2015 7:00:17 PM. by JAI PRAKASH. Forum started by Jag
1922
Leaking Ceiling
Last answer on 8/25/2014 8:26:28 PM. by JAI PRAKASH. Forum started by sandipvora
1927
bathroom dampness
Last answer on 12/23/2013 12:21:54 PM. by S L Gupta (Civil Engg). Forum started by sunder
2570
Basement Leaks
Last answer on 10/24/2013 11:40:09 AM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
2531
Reasons of dampness
2366
water treatment for walls
Last answer on 4/27/2011 7:37:34 PM. by S L Gupta (Civil Engg). Forum started by gajender pathak
1749
2086
Last answer on 4/12/2010 8:36:47 PM. by haritha. Forum started by sujani
Protect
Happy
Happy New Year 2009
Fire
Orientation
Orientation of Building
Earthquake
Damp
Damp Proofing
