I am constructing a home and the area size is 28 X 21. It has 9 Pillars each has
Tue Jan 30, 2018Total posts : 7
KV
KV
Topic: I am constructing a home and the area size is 28 X 21. It has 9 Pillars each has
I am constructing a home and the area size is 28 X 21. It has 9 Pillars each has 9’ X 12 ‘ with 12mm rods of 6. Planning to change the room size and making the center pillar as Dummy. Kindly suggest is it fine to make change?
Wed Jan 31, 2018Post  #1
       It is not clear that you are constructing new construction or emending the old construction. Write in detail what type of information do you need.
Wed Jan 31, 2018Post  #2
KV
KV
Hi Gupta Ji,
Thanks for your quick reply. It is a duplex home constructed by my family. Living room has been extended. Now G Floor is in finishing stage. Looking for the strength of the building to construct more floors.
Thu Feb 01, 2018Post  #3
          Without detail design and drawing it is difficult to comment on the strength of building. In my opinion it is better to contact any civil engineer who can guide better after inspection the house site and after taking the idea about loading and foundation to take load of further construction of floors.
Sat Feb 03, 2018Post  #4
Er.S.K.Jain
Er.S.K.Jain
If you remove center column it is sure that unsafe for third floor.
Further to remove center column in ground floor or first floor its depend on foundation and slab design details.
Better contact local civil engineer and don't take risk.
Wed Feb 14, 2018Post  #5
KV
KV
Post subject: Need Help regarding building strength
My Brother is constructing a building G+ 1 Duplex home which is almost in Finishing stage. Columns  are 12 X 9 with 6 12mm rods. Center one highlighted in Yellow has been made dummy due to the change in Plan and Beam with 16 mm rod has been Provided from the structural beam(Highlighted in Yellow). All the walls are built in the same structure in First Floor. One of his friend recently visited the place and told building strength will be a question since there is no Center Column. He is very much worried now. Could you please help. what corrective action can be take now?
Attachments: IMG_20180211_100910.jpg Wed Feb 14, 2018,&n
Sat Feb 24, 2018Post  #6
Er.S.K.Jain
Er.S.K.Jain
As per attach map the center column not must for two storied building and you may be removed it but depend on slab and beam design.
if you remove column after costing the slab it is dangerous and you need to place support by ISMB frame section as per design.
Mon Feb 26, 2018Post  #7
KV
KV
Thanks a lot for the reply. Center column highlighted in Yellow has been removed before the slabbing of Ground floor.
2540
Last answer on 7/4/2020 2:31:17 AM. by S L Gupta (Civil Engg). Forum started by ramaiyacp
3474
1334
3510
1398
I am planning to buy a residental 21*89 plot..is it good dimension??
Last answer on 2/25/2022 6:03:38 AM. by S L Gupta (Civil Engg). Forum started by KARAN KAPOOR
1570
2171
Exterior work
Last answer on 5/31/2013 12:38:45 PM. by S L Gupta (Civil Engg). Forum started by ANAND
1617
I have open site of 30'*50' size. I want to construct an house having sitout din
Last answer on 4/4/2018 1:22:54 AM. by S L Gupta (Civil Engg). Forum started by appasaheb
2264
Last answer on 7/4/2016 5:42:09 PM. by S L Gupta (Civil Engg). Forum started by Aniket
2305
1809
what re these in gharexpert estimates
Last answer on 12/17/2015 2:57:41 PM. by JAI PRAKASH. Forum started by sushantsah
3238
4449
if y have t junction plot what is the solution i am having south facing plot wit
Last answer on 8/21/2014 2:37:19 PM. by Dilavarsinh Vaghela. Forum started by sudhir samdani
2992
Basement Interior Design
Last answer on 11/26/2010 2:58:05 PM. by S.C.Chawla. Forum started by Boby
3230
1487
Hello Architects, currently i am having G 1 house with 1250sqf area with 12 colu
Last answer on 3/15/2016 1:20:57 PM. by S L Gupta (Civil Engg). Forum started by babu
1515
I am constructing a house in Dharamsala ( place having second highest rain falll
Last answer on 12/21/2015 1:41:44 PM. by Bhupinder Kumar. Forum started by Bhupinder Kumar
1529
I am having 30x40 plot facing south and i want to construct house with east faci
Last answer on 7/3/2020 11:36:54 PM. by S L Gupta (Civil Engg). Forum started by DINESH P
18
Brick Pillar
Rugs
Rugs for Living Room
What
What is recommended size and shape of building for the protection in earthquake prone areas?
All parts of a building should firmly be tied together and stiffly braced at corners in such a manner that the whole s..
Right size cupola
