I am constructing a house with basement 2. After raising the pillars can i imm
Fri Aug 25, 2017Total posts : 3
Joseph Santhosh
Joseph Santhosh
Topic: I am constructing a house with basement 2. After raising the pillars can i imm
I am constructing a house with basement 2. After raising the pillars can i immediately start the ground floor concrete or do i need to wait for some days. Which is the best cement for this purpose?
Mon Aug 28, 2017Post  #1
       You can start the ground floor work after laying the slab of basement. Cement from any reputed brand to be use.
Mon Aug 28, 2017Post  #2
Sumit Kothari
Sumit Kothari
Yes you can easily start with the construction but proper curing of basement slab should be done and don't forget to  provide the support of prop jacks under the basement slab too while casting of your Ground floor slab with proper use of vibrator.
Thu Aug 31, 2017Post  #3
Sumit Kothari
Sumit Kothari
Your welcome Sir!
3591
18416
2935
Number and position of pillars
Last answer on 7/3/2020 10:41:58 PM. by Ananda. Forum started by Ananda
2176
2592
Renovation of old house
Last answer on 5/24/2013 5:06:03 PM. by chandrakanth. Forum started by chandrakanth
5755
2851
Bricks
3976
4983
Input required on Basement parking
Last answer on 7/20/2012 4:07:42 PM. by S L Gupta (Civil Engg). Forum started by vinay
2237
Sreel pillars(post)
13773
Pillar & plinth beam frame work avoiding stone foundation
Last answer on 5/11/2017 11:22:09 AM. by S L Gupta (Civil Engg). Forum started by tp_bangalore
2812
Vastu Guidelines for Basement
Last answer on 7/13/2009 8:11:17 PM. by Naveen Mereddy. Forum started by shivani
2869
2703
BAsement construction
Last answer on 11/8/2012 5:34:56 PM. by sheree123. Forum started by Gagandeep
1615
i am asking for staircause ...Run=5feet,Raise=9feet......in this situtation ..wh
Last answer on 4/22/2016 12:12:17 PM. by S L Gupta (Civil Engg). Forum started by Selvan
2084
in concrete piller using more cement sand than20 mm jelly what is the result will be?
Last answer on 5/19/2015 9:17:17 PM. by JAI PRAKASH. Forum started by manja nayka k r
3984
2752
Last answer on 8/26/2013 1:23:28 PM. by S L Gupta (Civil Engg). Forum started by ragha
278
82
29
26
31
31
30
28
28
29
25
25
21
31
22
30
27
23
Brick Pillar
Basement Design Ideas
Basement Ceiling
Basement Flooring
Basement Interior Design
