Thu Jun 24, 2010 | Total posts : 5 |
| Topic: I am in delhi constructing my house.can you please tell me how much these brass/
I am in delhi constructing my house.can you please tell me how much these brass/bronze/coper doors cost and where they stand when compared to woodn,pvc,fibre and other types of doors
sachin jain
The comment above talks about the image below. Click on the image to enlarge.
Fri Jun 25, 2010 | Post #1 | jyoti
Join date: Jun 2010 | I AM DELHI BASED AR& INTERIOR DESIGNER,YOU CAN CONTACT ME FOR MORE BEAUTIUL & BETTER OPTIONS AS PER YOUR SITE,NEED & LIKINGS. idjyoti@yahoo.com.
JYOTI
AR & INTERIOR DESIGNER | |
Fri Jun 25, 2010 | Post #2 | Richa Shangvi Interior decorator
Today doors industry is also working very hard on designing and using different material for doors. As far as wooden doors are concerned they are unbeatable if designed/ chosen as per the theme of the home/office.
Actually entrance/main gate of you home should look different and exclusive. Today we can have bronze, copper, brass, aluminium even steel on doors. But Steel doors give the commercial look. Even the combination of material is being used in homes.
Glass doors are out of trend now.
Brass is really expensive. Pricing depends on weight, carving/design of door. Kindly contact expert for it
Sun Jun 27, 2010 | Post #3 | jyoti
Join date: Jun 2010 | YOUR REQUIREMENT RELATED TO DOORS IS NOW SOLVED OR NOT.
IF NOT ,DO DISCUSS WITH US.
JYOTI
AR& INTERIOR DESIGNER | |
Wed Jun 30, 2010 | Post #4 | Richa Shangvi Interior decorator
Actually dimensions always matter. Latest rates for brass doors ranges between Rs.4200 - 4500 per square feet. The depth of carving and size is the important factors in the total price calculation. If you need it, contact gharexpert for the variety of designs and delivery at your place. | |
Wed Jun 30, 2010 | Post #5 | Anil Kumar Mishra
Brass door is not suitable for use except in puja room.Ignore using brass doors. It is better to use gold/silver doors considering vastu. | |
Articles that might interest you! | | Gharexpert can save you money during construction Do you know almost all individual home construction projects in India take more money to complete than what people ori.. | | Brass Doors Brass doors are very popular for Georgian and Victorian types of architecture in ancient buildings. Today brass doors .. | | Advantages and Disadvantages of Brass Doors. Advantages-Artistic and elegant appearance ,Disadvantages-Unsuitable for harsh weather conditions,require polishing..... | | Are you constructing a cupboard, Learn the difference between wood-only and wood-brick cupboards Cupboards construction using different materials: Brick and Wooden Cupboards, Just Wooden Cupboards, Mesh Cement and W.. | | What is the standard size of internal brass doors? Standard size of internal brass doors..... | | Which types of bricks are recommended to protect the dampness while constructing the building? The density of masonry bricks used must be greater than 1200 kg/m³. | | Planning a House Once the architect has given his design options, it becomes necessary to select one and start working on it. | | Layout of Building The real meaning and purpose of setting out (layout) is to transfer the plan, length and width of its foundation on th.. | | Painting Exterior of your Home For painting exteriors of your home, you should know proper guidelines on primer, paint quality, paint color, weather .. | | Environmentally Friendly Houses An environmentally friendly house is designed and built to be in tune with its occupants, nature, environment and ecos.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
