Sat Nov 26, 2011 | Total posts : 0 |
| Topic: I am planning to make a mini pool in my house. Not under ground but on ground l
I am planning to make a mini pool in my house. Not under ground but on ground level. please advise me about it's location as per Vastu. The house construction is yet to start as I am working on my house layout/ Floor Plan. Can some one help me out? Thanks in advance. Vee Kay. |
Articles that might interest you! | | Inground Swimming Pool If you are planning to install an in ground swimming pool in your home, you can find a range of designs and styles to .. | | Swimming Pools to Match Your Lifestyle Swimming pools are rich sources of pleasure. They not only amuse us but energize the body also. They provide extreme r.. | | Pool Pumps Pool pump is the most important equipment of your swimming pool. This device works with filter to maintain the cleanline | | Preliminary Works during Ground Work Entire area should be cleared of all roots, bushes, vegetation etc. for a smooth construction works. | | Pool Heaters You spend a lot of money to construct a swimming pool and on its other equipments. But if your pool is frequently too .. | | Planning a House Once the architect has given his design options, it becomes necessary to select one and start working on it. | | Which are various types of door viewers for houses? The Mini Scope door viewer is a unique 200 degree peephole that is designed to fit thin doors.
| | Terrazzo flooring (Mosaic or Marble chip flooring) Terrazzo flooring is popular for residential as well as public buildings since it is not slippery when wet.
| | Swimming Pool Covers Pool covers become an important thing when the swimming season ends. As they reduce evaporation as well as protect you.. | | Swimming Pool Maintenance Maintenance of a pool is a major requirement that must not be taken lightly. Read this article to know tips on how to .. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
