I am planning to renovate my floor with vitried tiles. Contractor is suggesting
Wed Apr 06, 2011Total posts : 3
RKG
RKG
Topic: I am planning to renovate my floor with vitried tiles. Contractor is suggesting
I am planning to renovate my floor with vitried tiles. Contractor is suggesting that it is better to break the existing mosaic floor and then relay the tiles to achieve better stability. Some are syaing that it is fine to lay vitried tiles over existing mosaic floor with god adhesive with the only loss being the hight of room will reduce by an inch or so.. i have time and empty house for the work . what is better?
Wed Apr 06, 2011Post  #1
Dear RKG
          You should made floor rough by chilling and than fix the vetrified tiles with good quality adhessive. Care should be taken that before laying the tiles surface should be clean.
Tue May 16, 2017Post  #2
shashank Agrawal
shashank Agrawal
Hello RKG, i'm also facing a similar situation, may i know what did you choose and why? if you choose to lay tile over the existing mosiac, what has been your experience and what process and material you used?
Your insights will be really helpful for me and probably many more people.
Thanks,
Shashank
Wed May 17, 2017Post  #3
Dear Sir
          You should made floor rough by chilling, clean with wire brush than do final cleaning, and than fix the vitrified tiles with good quality adhesive. Care should be taken that before laying the tiles surface should be clean.In this process you have to cut door shutter to reduce the shutter size according to floor height. In past 10 years in govt. building 90% marble floor replace by ceramic tiles by using this method.
Basement Water proffing
2621
Tiles
Last answer on 7/11/2020 8:08:42 PM. by freekundli. Forum started by Ahmed
1531
I am planning to renovate my house,the stairs placed in such a way it rises from
Last answer on 2/4/2017 11:38:29 AM. by S L Gupta (Civil Engg). Forum started by sreeraj
3325
2935
Right price or not .. Kindly advise
Last answer on 7/3/2020 9:28:23 PM. by S L Gupta (Civil Engg). Forum started by everfor
1846
3382
2466
how to proceed with plan approval by the authorities
Last answer on 10/29/2012 4:09:00 PM. by S L Gupta (Civil Engg). Forum started by latha
32662
Are there any problems in pasting tiles over an existing mosaic floor?
Last answer on 7/3/2020 10:21:35 PM. by Srinaath KS. Forum started by sunilbs9999
4384
2331
2104
I have a 1650sq ft flat which I am renovating What company/material I use for a
Last answer on 4/14/2013 3:03:56 PM. Forum started by capt vngautam
3494
I AM LOOKING FOR A FLOOR PLAN FOR 36X72 PLOT WITH 3 BEDROOMS AT GROUND FLOOR .
Last answer on 2/26/2012 2:32:46 PM. by aman. Forum started by INDER PAL
3229
1474
hello,I am planning to renovate my house as per Vastu.plot is southeast facing,
Last answer on 3/5/2016 10:37:06 PM. by JAI PRAKASH. Forum started by Sheetal Jain
1516
Tiles or Granites
Last answer on 9/14/2016 2:30:34 PM. by sanjay agarwal. Forum started by M Prabhu
1756
structure work
Last answer on 8/20/2016 12:45:01 PM. by S L Gupta (Civil Engg). Forum started by manish agarwal
1763
1668
Bedroom Makeover
Tile
Tiles
Tiles for Bathroom
Designing
