Home -> Forums -> Construction -> Brick work -> I am purchasing a land 42x62 i want to make my home please give us idia
Mon Mar 19, 2012Total posts : 1
DILIP
DILIP
Topic: I am purchasing a land 42x62 i want to make my home please give us idia
Thu Jul 05, 2012Post  #1
Post subject: Use floor plans service at minimal cost
  • You select a plan whose layout you like. Note down the plan code and purchase the plan.
  • Once you purchase the plan, we will contact you and send you a questionnaire through which we will understand your requirements.
  • We will assign a representative for your project and he/she will coordinate all your requirements.
  • After discussions with you, we will adjust the plan according to your exact plot size and make as many changes as you like. Our prices are based on per square feet of built area and if after changes your built area increases by more than 10% then we will change for the increased area accordingly.
  • If you also purchase guidance from Vastu expert then an independent vastu expert be assigned toyour project and he/she will review your plan and suggest changes.
  • Once the plan is finalized, we will give you dimensions as shown in the sample drawing and door window schedule.
  • If you purchase more drawings then the same will be delivered to you according to the plan finalized by you.
  • If you choose a 3-D option too, then the process works as below.
    • After completion of the architectural plans, we will recommend and send to you a few pictures/3-D models of the homes. In those pictures, we will ask you to shortlist the items of the exterior elevations. You can also send us the pictures of homes that you like. Through the existing pictures, it will be easier for you to shortlist the material and shape of exterior elevation.
    • Based on the architectural plans and your preferences, our 3-D designers will design the 3-D elevation for your home.
  • If you purchase, 3-D elevation plan then you should also purchase the 2-D elevation plan as all dimensions and levels are provided in the 2-D elevation plansYour contractor would use the details in the 2-D elevation plan to construct your home. The 3-D pictures are there for a reference so that both you and your contractor can visualize the same thing.
1839
East to West 30sft and North to South 20sft any plan for me with pillers
Last answer on 1/10/2016 8:50:06 PM. by JAI PRAKASH. Forum started by ANANTH KUMAR K N
1888
I have a piece of land 25'width/50'length.Pls. suggest me for home making archit
Last answer on 2/19/2019 11:23:49 PM. by Saurav anand. Forum started by ashish panchal
2582
Last answer on 7/4/2020 2:41:58 AM. by Amit Hasija. Forum started by pradeep kapoor
191896
2782
we 1925sq feet noth facing land,we want to construct a appartment give us the be
Last answer on 1/26/2012 5:43:51 PM. by Rajani. Forum started by Rajani
1444
Please provide me a best home plan for a land of 40'x 21'
Last answer on 10/18/2016 11:17:52 AM. by Beenu Phogat. Forum started by Subrata
3498
Vastu Tips for Office
Last answer on 7/4/2009 4:36:57 PM. by Nageshwar. Forum started by sunil patel
8045
17 feet by 30 feet south face home design sir please give me a design
Last answer on 5/8/2017 12:41:49 PM. by Saurav anand. Forum started by Rav kumar
1810
1865
Geotechnical Lab
Last answer on 8/2/2010 2:34:40 PM. Forum started by arun
2794
SOLAR FOUNTAIN IN GARDEN OUTSIDE AREA HOW MUCH COST, WHERE CAN i PURCHASE, PLEAS
Last answer on 9/17/2021 1:06:03 AM. by Gunjan Utraja. Forum started by Jagajothi
2263
Last answer on 7/4/2016 5:42:09 PM. by S L Gupta (Civil Engg). Forum started by Aniket
1554
2509
interiors for bedroom
Last answer on 7/19/2016 2:49:37 PM. by AR. HIMANSHU PHOGAT. Forum started by sowmya
3556
Last answer on 3/29/2017 9:32:31 PM. by Saurav anand. Forum started by K M N GANESH
3895
Construction software
Last answer on 1/2/2021 5:22:24 AM. by DK. Forum started by tvammu
2001
1812
can a plot be purchased which a curving road in front giving it a kite shape
Last answer on 8/21/2015 12:18:38 PM. by Nageshwar. Forum started by virendra
4554
24x60 west facing old home renovation Idea
Last answer on 7/3/2020 11:25:30 PM. by S L Gupta (Civil Engg). Forum started by rajeev
3668
wals
3262
compound wall
21868
3279
Bedroom Wardrobes information
2244
2205
1494
1965
1732
2223
2523
1501
1907
Brick or ACC block
2024
1653
1702
4680
Brick wall on RCC slab
3928
2616
Buying tips for Brick Blast
Buying
Buying tips for Cement
Tips to remember while purchasing a garden bench.
Ready
Ready Made Doors
Are you looking for appealing ready made doors for your home? Here is a variety of ready made doors to provide safety ..
Buying tips for Bricks
Precautions
