I have Plot having are 48'Back, 45' Front, 80' Right and 78' Left.Front side 21
Tue Jun 25, 2013Total posts : 1
sanjay
sanjay
Topic: I have Plot having are 48'Back, 45' Front, 80' Right and 78' Left.Front side 21
I have Plot having are 48'Back, 45' Front, 80' Right and 78' Left.Front side 21 feet Road and Right side 14 feet common passage.Please suggest what could be done here.
Fri Nov 22, 2013Post  #1
Dear Mr.Sanjay
Last answer on 8/1/2013 11:47:54 AM. by Gunjan Utraja. Forum started by sanjay
12442
45*75 cornar plot with 8 fit front on 45* side
Last answer on 10/16/2014 12:27:36 AM. by JAI PRAKASH. Forum started by agam
1548
2769
Is the construction on the plot having east facing , and wider on front side and
Last answer on 9/6/2010 9:29:25 AM. by Gunjan Utraja. Forum started by Praveen
3031
Last answer on 2/21/2022 6:45:23 AM. by S L Gupta (Civil Engg). Forum started by parkash
2483
map design
Last answer on 4/14/2014 11:28:10 AM. by S L Gupta (Civil Engg). Forum started by sushil
1760
2675
plot having west side &south side road
Last answer on 8/21/2014 2:42:37 PM. by Dilavarsinh Vaghela. Forum started by rahul kulkarni
2742
Last answer on 8/11/2017 2:15:35 AM. by HOME. Forum started by parveen sharma
1751
my plot have south side front, i want to know vastu for my planning house which
Last answer on 5/3/2016 11:38:34 PM. by JAI PRAKASH. Forum started by ROHIT KUMAR
1772
have to dug a te,right,left back,front,any corner?ube well which is the proper p
Last answer on 2/29/2012 9:06:08 PM. by viswanatha kamath. Forum started by BASHIR THAKUR
1939
kitchen back side of home ya front left side ???
Last answer on 3/22/2013 1:02:39 PM. by akmurty1. Forum started by Surjeet
WHEN I HAVE MAIN DOOR IN EAST FOR A EAST PLOT IS IT NECESSARY TO HAVE A OPENING
Last answer on 8/1/2011 11:13:07 PM. Forum started by D.Ramachandran
2146
size of house planned 35 ft front and 45 ft depth with 1st floor
Last answer on 5/12/2016 6:07:13 PM. by Lingraj Halli. Forum started by ROHIT KUMAR
1812
KINDLY SEND 24* 45 CORNER HOUSE FRONT AND CORNER ELEVATION 3 STORIES
Last answer on 2/7/2017 12:59:59 PM. by S L Gupta (Civil Engg). Forum started by balwinder singh
1906
can we bought a plot which have broad front side
Last answer on 2/6/2010 8:29:26 PM. by sabina vanjani. Forum started by rahul015
2473
2237
my plot size is 26X35 west facing and right and left side of plot is block. i w
Last answer on 12/13/2013 11:21:27 AM. by S L Gupta (Civil Engg). Forum started by kailash aute
1518
Is it necessary to leave 3feet distance as a front setback in house plan or we c
Last answer on 10/10/2017 12:39:29 AM. by S L Gupta (Civil Engg). Forum started by VIPUL BHALDE
Hardwood
Hardwood door
Hardwood
Hardwood window
Landscaping
Landscaping for a Small Space
Basic rules while designing the light.
Every activity that takes place in the interior must have lights of the right kind, intensity and the right direction.
Right size cupola
Finding
Finding Right Folding Tables
Folding tables are portable, affordable and space saving, available in a variety of designs and shapes. These tables p..
