Mon Jun 13, 2016 | Total posts : 1 |
| Topic: I have a bungalow in which I stay presently size 1200 sq.ft. area. I want to bui
I have a bungalow in which I stay presently size 1200 sq.ft. area. I want to build the first floor comprising of 3 rooms and leave some vacant place (size of a room. What should be the building cost estimate. Please note i assume there will be no foundation cost. |
Articles that might interest you! | | What is acre Acre is traditional measure area unit, to measure the land in bulk mostly in agriculture and forestry. The abbreviation | | Aluminum door frame standard size There are various options of sizes in aluminum doors available in market. Choose the right one according to your purpo.. | | Rugs for Living Room Give modern and contemporary look to your living room with wide range of area rugs and carpets. Living room rugs are p.. | | What is recommended size and shape of building for the protection in earthquake prone areas? All parts of a building should firmly be tied together and stiffly braced at corners in such a manner that the whole s.. | | Right size cupola This article contains information about the size of cupola | | Selection of A Site The selection of a site depends upon ones present and future spatial requirements, the envisaged available funds, one’.. | | Utilization of Space Under Stairs It seems that most people forget to decorate the space under stairs. Though the space is small yet it’s easy to create.. | | What is the recommended size of wooden boards for wooden board flooring? Boards of hardwood or softwood are of good quality and free of knots.The usual thickness of the boards is 19 mm or 25 .. | | What is the standard size of plywood for wooden Windows? The Standard sizes of plywood are following:
| | What is the standard size of plywood? Plywood is available in thickness ranging from 3mm to 25mm as 3 to 9, 12, 15, 16, 19, 22, and 25(mm).
| | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
