Home -> Forums -> Vastu -> Bedroom -> I have a plot of 100sq.ft. Please tell me which location is best for prosperity
Fri Nov 18, 2011Total posts : 1
Sanjeev Birla
Sanjeev Birla
Topic: I have a plot of 100sq.ft. Please tell me which location is best for prosperity
I have a plot of 100sq.ft. Please tell me which location is best for prosperity and financially strong and for the business in vastu Ghar.
Wed Dec 07, 2011Post  #1
ramu771964
ramu771964
Post subject: Suggesstion - V.Ramakrishna - Vastu consultant.
Actually You have not mentioned your PLOT facing .
If you send clear Plot dimensions with Road facing of your Plot, some suggession I can give you.
It is always good to have House Maindoor facing North, East (or) North, but other Facings also can be better if constructed as per Vastu. But now a days as space is very expensive every one cannot be able to follow as per Vastu and face after effects by making adjustments.
It is better to follow Vastu as much as we can to avoid after effects.
V.Ramakrishna,
vanapalli77@gmail.com
Bedroom-Vastu Questions (39)
2391
Last answer on 11/21/2013 10:05:53 AM. by S L Gupta (Civil Engg). Forum started by RAGUVINDER SINGH
191937
1338
3046
Last answer on 8/18/2011 6:51:51 PM. by prasadtvp. Forum started by chella earnest
1971
plot size 31 ft X 78 ft. facing south.please provide best possible layouts
Last answer on 5/18/2015 11:50:41 AM. by seema tyagi. Forum started by ravi shanker
2324
i have 17x49 ft plot, please tell me about house plan.
Last answer on 4/25/2013 9:32:08 PM. by Gunjan Utraja. Forum started by naveen
868
Sir I have a plot size 24x65 west facing and a 6 ft gali on left (north side)Ple
Last answer on 7/30/2020 8:16:06 AM. Forum started by S P Srivastava
1930
CONSTRUCTION DESIGN
Last answer on 3/8/2017 2:40:59 AM. by S L Gupta (Civil Engg). Forum started by MANISHA
1808
Sir, my plot is west and south facing with Total size of size of 31x38 Ft, pl
Last answer on 4/25/2021 6:53:14 PM. by S L Gupta (Civil Engg). Forum started by Swatej Kumar
2482
2502
Which is best location for main door in east facing plot as per the purvashadha
Last answer on 1/2/2021 5:22:27 AM. by Nageshwar. Forum started by Srinath
8690
i have 15 ft width & 30 ft length plot which ihas to develop tell me the plan &
Last answer on 10/28/2021 12:01:35 AM. by S L Gupta (Civil Engg). Forum started by RANJIT SINGH
1886
7351
Last answer on 8/25/2015 6:07:17 PM. by JAI PRAKASH. Forum started by RITESH
3836
4458
if y have t junction plot what is the solution i am having south facing plot wit
Last answer on 8/21/2014 2:37:19 PM. by Dilavarsinh Vaghela. Forum started by sudhir samdani
2852
HOUSE MAP
Last answer on 7/3/2020 10:37:26 PM. by S L Gupta (Civil Engg). Forum started by Pankaj
5692
Having a plot of 30'X40' south facing, want to know floor plan up to 700 sq ft w
Last answer on 2/16/2019 2:25:41 AM. by Amit Hasija. Forum started by viairsung
2096
My House is north facing please tell which is best direction for installing wate
Last answer on 11/19/2012 11:30:26 AM. by Amit Hasija. Forum started by Anuj Anand
2346
VATU OF FIRST FLOOR inDuplex
Last answer on 2/13/2022 6:46:20 PM. by geetika. Forum started by Anoop
1897
Home Entrance- South East
Last answer on 1/22/2022 12:39:20 AM. by S L Gupta (Civil Engg). Forum started by Jitesh Rughani
10018
Please help me if northeast corner cut is correct.
Last answer on 1/8/2022 8:14:43 AM. by Robin Goswami. Forum started by Neha
2064
Last answer on 12/21/2021 1:37:30 AM. by S L Gupta (Civil Engg). Forum started by SACHIN
2706
Last answer on 12/2/2021 6:58:04 AM. by S L Gupta (Civil Engg). Forum started by Satvinder kaur
3269
bedroom tree vastu
Last answer on 9/29/2021 7:10:55 AM. by Anil Kumar Mishra. Forum started by Samarjit Roy
6988
VAASTU FOR APARTMENTS
3169
Why one should refer to the Vastu?
Last answer on 6/2/2021 8:57:38 PM. by Deepak. Forum started by Priti Arora
4675
Last answer on 3/5/2021 2:45:15 PM. by Pavan. Forum started by anjli
2785
Children room
Last answer on 12/31/2020 2:16:24 AM. by Priti Arora. Forum started by madlika
2841
yes room is very beautiful but not ideal for indian houses
Last answer on 12/31/2020 2:05:28 AM. by juhi. Forum started by nivia
2557
map for new house
Last answer on 8/11/2020 1:03:40 AM. by S L Gupta (Civil Engg). Forum started by jassmann
7413
Last answer on 7/20/2020 11:36:14 PM. by Gunjan Utraja. Forum started by srinivas
3302
book shelf
Last answer on 7/13/2020 3:59:55 AM. by S L Gupta (Civil Engg). Forum started by Prabha
2479
Last answer on 7/9/2020 4:06:40 AM. by S L Gupta (Civil Engg). Forum started by sarasrl
2915
nice design
Last answer on 7/9/2020 4:04:00 AM. Forum started by jaswindersingh
2175
Last answer on 7/8/2020 11:15:27 PM. by S L Gupta (Civil Engg). Forum started by dheeraj miittal
2292
Last answer on 7/4/2020 3:34:50 AM. by S L Gupta (Civil Engg). Forum started by yasothabalanr
4690
L-shaped room?
Last answer on 7/4/2020 2:27:12 AM. by bijumohang. Forum started by bijumohang
3240
apartment vastu
Last answer on 7/4/2020 2:11:34 AM. by geetika. Forum started by bobby
What is acre
Appropriate
