I have built a house in 1600 sqft in ground floor with out piller beam. now I wa
Wed Dec 21, 2011Total posts : 2
siba charan sahoo
siba charan sahoo
Topic: I have built a house in 1600 sqft in ground floor with out piller beam. now I wa
I have built a house in 1600 sqft in ground floor with out piller beam. now I want to built 1st floor with piller beam. is it possible. if possible please suggest me how to get prepared for 1st floor on the ground floor.
Wed Dec 21, 2011Post  #1
Dear Sahoo
         Please consult civil engineer/ arcitecture of your city for this work who can give you best solution after inspecting the site of your house.
Mon Dec 26, 2011Post  #2
ravi at Dalmia
ravi at Dalmia
Hi Siba, before going for any sort of construction consult a construction expert. Building a floor above certainly would put weight on the bottom part thus it has to be strong and as you said its made without pillar beam, it can be dangerous. So consult the experts before proceeding.Regards.
Also check Dalmiabharat(.)com
stone foundation
8653
10312
900 Sqft column required
Last answer on 7/21/2021 11:11:14 AM. by S L Gupta (Civil Engg). Forum started by Shivaraj
2610
2995
5856
6455
1000 sqft only ground floor Contrusction Plan ideas Modern home
Last answer on 1/8/2015 11:58:36 PM. by JAI PRAKASH. Forum started by RAKESH NIRMALKAR
2695
1871
15296
First floor Construction cost
Last answer on 1/4/2013 11:30:16 AM. by S L Gupta (Civil Engg). Forum started by gomathi
3642
I want to built a house with stilt,ground floor
Last answer on 8/30/2021 6:11:55 AM. by S L Gupta (Civil Engg). Forum started by venkatesha
3624
Wall unit
3304
2821
building a house
1596
i want to build 300 sqft houuse want a elevation model house
Last answer on 7/3/2020 11:49:54 PM. by S L Gupta (Civil Engg). Forum started by vimaladevi
Need Construction cost of G+1 house in Sanghvi, Pune
Last answer on 6/21/2016 9:15:47 AM. Forum started by rakesh
3200
Ready Mix Concrete
3230
3821
What is the plinth Beam properties for Ground +3 residential building?
Last answer on 10/14/2013 1:14:49 PM. by S L Gupta (Civil Engg). Forum started by ananth
24
28
Orientation
Orientation of Building
Preliminary
Environmentally
Environment
Environment Friendly Houses
Centering
