What is the recommended size of wooden boards for wooden board flooring? Boards of hardwood or softwood are of good quality and free of knots.The usual thickness of the boards is 19 mm or 25 .. |
Stair construction-Things to remember Stair construction needs major consideration while you are either building a new home or just doing any renovation. Th.. |
| Designing a Foundation Foundation is the part of structure below plinth level and needs special care while designing. Whole design of the fou.. |
