I have to live on the top floor ( approx 3300sq ft) of a three storied building
Sun Jun 12, 2011Total posts : 2
Dr. Tiwari
Dr. Tiwari
Topic: I have to live on the top floor ( approx 3300sq ft) of a three storied building
I have to live on the top floor ( approx 3300sq ft) of a three storied building at Asansol( temp reach 48deg during summer). I am worried about the heat and hence I have planned to put a false ceiling in the 3 bedrooms. Does it really help and what additional can I do to keep my floor cooler. Does an exhaust fan between the RCC ceiling and false ceiling really help? How should I cover my entire terrace( over my floor) to reduce heat? Is it to be covered with tiles ( what type of tiles) or white paint( then what brand) or something else!!! pls help before I get grilled... regards
Mon Jun 13, 2011Post  #1
Dear Tiwari,
False ceiling reduce the heat coming from roof. Exaust fan also helps to reduce the heat of the room. There are many methods for providing thermal insulation for roof to reduce the heat. The website gharexpert.com construction section have lot of material about construction and maintanance of home. You should take help from the article of thermal insulation, whose link given below.
http://www.gharexpert.com/articles/Finishing-1607/Thermal-Insulation-Home_0.aspx
Wed Jun 29, 2011Post  #2
subhakankhi
subhakankhi
Post subject: Plant a plant...
You can adopt under-deck insulation of the roof to minimize heat gain in the interior space.
Providing shade to the roof top is the best way to reduce heat. I would advice go for creeper plantation on elevated structure above your roof. It will reduce heat, give beauty to your space. You have to take care of any problem due to water leakage.
Thanks.
Subhakankhi.
1191
I have an area of 1944sq feet in this I want graden and three floors house gron
Last answer on 4/23/2018 11:19:21 PM. by S L Gupta (Civil Engg). Forum started by Dilip Teja .G
1955
Dear Friends,I am the youngest of the 3 brothers. We have a 3 story building and
Last answer on 1/22/2017 1:28:20 PM. by Hari Kumar N. Forum started by Hari Kumar N
2496
Cost estimation for 3 stories apartment
Last answer on 11/23/2015 1:51:56 AM. by JAI PRAKASH. Forum started by Akshay
1334
20668
Heat reduction in the top floors
Last answer on 3/15/2011 10:12:45 PM. by Rohan Jaacob. Forum started by Dr. Tiwari
2354
what would be the cost of construction for this kind of house for approx floor o
Last answer on 8/21/2010 12:50:17 PM. by S L Gupta (Civil Engg). Forum started by bhavin
1570
Construction of house in Sushant Lok 2 Gurgaon
Last answer on 10/18/2016 11:58:38 AM. by om shrivastava. Forum started by om shrivastava
1498
I have a plot of land having length 44 ft and width 30 ft south facing,in the Ko
Last answer on 6/28/2016 11:30:26 AM. by Beenu Phogat. Forum started by bibhu adhikary
2555
Need support regarding Beam steel design
Last answer on 1/7/2014 2:57:59 PM. by S L Gupta (Civil Engg). Forum started by Sunil Kumar
5684
Having a plot of 30'X40' south facing, want to know floor plan up to 700 sq ft w
Last answer on 2/16/2019 2:25:41 AM. by Amit Hasija. Forum started by viairsung
191901
2287
roofing
Last answer on 6/18/2013 11:26:13 AM. by S L Gupta (Civil Engg). Forum started by sanjayagt
2321
2024
2948
Lightweight Concrete Roofing
Last answer on 10/31/2012 12:32:07 PM. by S L Gupta (Civil Engg). Forum started by Ted Junior
2419
Last answer on 10/18/2016 5:20:22 PM. Forum started by sandeepkelkar
3368
2062
15
17
What is acre
Living Room Furnishing
Living room furnishings add life to your dull living room. In this article, you will find some interesting and practic..
Rugs
Rugs for Living Room
Kitchen Counter Tops Part-1
Orientation
Orientation of Building
Living Room Ceiling
Kitchen design mistakes
Types of cupola
Let's find details about types of cupola in this writeup
