Layout and House Plans
Mon Apr 08, 2013
Mohiuddin
Topic: I need support for structural steel design for cloum /beam and slab
The comment above talks about the image below.
Click on
the image to enlarge.
Mon Apr 08, 2013
Dear Mohiddin
For structural drawing, there is need of plan of the building. The distance of columns to be taken according to the building plan,its elevation consideration. The design of column, beam and slab is according to the load bear by them and span of the beam and slab. However you can contact at support@gharexpert.com for structural design and drawing. There charges are very low in comparison to market.
Mon Oct 13, 2014
for providing support to existing structure RCC and working drawings are required. Structural Engineer will provide the required details
2557
Need support regarding Beam steel design
Last answer on 1/7/2014 2:57:59 PM. by
Sunil Kumar
2051
I'M IN NEED OF MS WORKSHEET FOR STRUCTURAL DESIGN
Last answer on 8/24/2021 2:39:40 AM. Forum started by
martin kevin red
1314
Last answer on 8/12/2020 3:57:29 AM. by
baba morris
Er.S.K.Jain
2039
Last answer on 6/16/2015 4:44:30 AM. by
Lawrence
2710
Last answer on 3/12/2021 10:44:44 PM. by
Lawrence
2306
Last answer on 2/22/2022 2:56:11 AM. by
Lawrence
2036
Last answer on 2/1/2022 6:06:54 PM. by
Lawrence
5694
Last answer on 7/3/2020 10:36:16 PM. by
sam_m400
1533
Guide me
Last answer on 3/22/2017 12:35:27 PM. by
Subash
2868
Steel calculation
Vamshidharreddy
1993
Residential complex
Last answer on 6/30/2021 4:27:52 AM. by
lali
1834
Last answer on 5/9/2016 2:06:50 PM. by
Last answer on 5/3/2016 12:13:14 AM. by
sayeedmohsin
2691
Last answer on 7/2/2021 3:17:17 PM. by
B Thakar
minhaj sk
3840
Roof Beam
R.Roy
6167
i want structural design of staircase in area 3.00mx 2.20 m
Last answer on 5/3/2014 7:45:54 PM. by
sudipta das
2569
roof of a building
Last answer on 7/3/2020 11:28:49 PM. by
sujata
11703
Last answer on 2/2/2022 12:01:14 AM. by
meenakshisundaram
4020
labor rate for RCC work
Last answer on 7/28/2020 1:27:06 AM. by
ringwang
ringwang
2695
Raj
2190
Amutha
2188
vanramr
2800
raghu
4524
Nitien Parmar
suryarao p
1892
santosh
2288
Deepak Giri
2272
ajay sharma
2773
u v sudhakar
3466
ramana
2360
srinivas kamsali
1974
tanaya483
2246
ramanapeddu
3598
SRIKANTH.S
2327
HIRA SINGH
2794
Alexander Graf
Mohiuddin
1552
uma shankar
2117
mohammedbasha
Dining Room Ceiling
Garden Path Ideas
