I understand TEAK WOOD (BURMESE AND KERALA) are expensive., if I want the next r
Wed Jan 06, 2016Total posts : 2
Vikram
Vikram
Topic: I understand TEAK WOOD (BURMESE AND KERALA) are expensive., if I want the next r
I understand TEAK WOOD (BURMESE AND KERALA) are expensive., if I want the next range of quality, can I choose with PINCODA or SOL wood.. Kindly explain , as timber market is massive , and immense doubt arrives over quality via appearance
Wed Jan 06, 2016Post  #1
Dear Vikram
     There so many verity of hard wood available in the market such as teak wood, sal wood , seasham wood, hollock wood, marandi wood and many other option, You should try to purchase from top most dealer after market survey. See the link below
http://www.gharexpert.com/articles/Raw-Material-1590/Purchasing-Guidelines-Timber_0.aspx
Sun Jan 10, 2016Post  #2
Teak wood can be used for doors, you can use Ivory cost wood as well if you have less budget, the more cheaper wood be Marandi and mango wood doors and the cheapest would be flush door.
1759
62
doubts regarding the purchase of wood....
Last answer on 3/14/2011 11:03:12 PM. by Dinesh Manaktala. Forum started by sangeetha
11410
WHAT IS TH PRICE OF TEAK WOOD IN BANGALORE
Last answer on 12/28/2011 10:07:52 PM. by S L Gupta (Civil Engg). Forum started by ramesh s
1486
I would like to know about what are difference and durability with cost about Ru
Last answer on 3/6/2017 4:18:34 PM. by Sree. Forum started by Sree
2034
2327
My husband wants to furnish the doors and windows completely with teak wood..but
Last answer on 8/5/2011 11:12:02 AM. Forum started by sangeetha
3490
17452
i want idea about main door which is teak wood but simple design to make modern
Last answer on 8/15/2013 7:15:40 PM. by GUNA. Forum started by ashok
2593
JOINERY WORKS
2423
What are various materials used for windows?
Last answer on 5/14/2014 1:56:15 PM. by S L Gupta (Civil Engg). Forum started by MANJUNATH
1781
What could be the cost of Teak wood main door (4.5'x9'), double unequal shutters
Last answer on 3/5/2016 9:49:38 PM. by JAI PRAKASH. Forum started by Suhas
2501
Wood quality check
Last answer on 9/1/2015 4:22:59 PM. by JAI PRAKASH. Forum started by Vijay
3741
Door wood and Frame
Last answer on 2/19/2013 11:35:56 AM. by S L Gupta (Civil Engg). Forum started by paresh
2105
I have a 1650sq ft flat which I am renovating What company/material I use for a
Last answer on 4/14/2013 3:03:56 PM. Forum started by capt vngautam
1985
lets know the cost of brass doors apart from saying that they r expensive.....hw
Last answer on 6/28/2010 3:17:30 PM. by Richa Shangvi Interior decorator. Forum started by sonu
3741
Pooja Room Vastu
Last answer on 10/3/2015 11:17:32 AM. by S L Gupta (Civil Engg). Forum started by sam
2075
6680
little detail required
Last answer on 10/22/2020 10:47:11 PM. by Navneet Jharia. Forum started by gaurav
17
Teak
Teak wood frame
What are various types of woods used in doors?
Primary and Secondary varieties of wood like Teak wood, Deodar, Shisham.....................
Cedar Wood
Wood
Wood Roof Shingles
Hard
Finishing recommended for wood ceiling
There are many type of ceilings are provided such as stretch ceiling, wood plank ceiling, or steel ceiling. But do w..
Garden
Garden Furniture
Garden furniture makes your garden relaxing place to sit. You can choose from a wide range of furniture like benches, ..
