Column and Frame Structure Building Columns are used to support the beam or roofs and transfer the load to the earth. These serve the decorative purpose a.. |
| Demarcation/layout Procedure Baseline is marked on the ground either from centre line of the road or from any permanent building nearby |
| Dining Room Ceiling Dining room ceiling designs can change the interior of your room. A white ceiling in your well furnished home looks du.. |
| Centering and Shuttering / Form Work Shuttering or Form work is most important part of any construction project. Steel, Wood or other likewise material is us |
| Mild Steel Bars in Cement Concrete Mild steel bars in reinforced concrete are one of the exceptional building materials. Reinforced concrete requires ver.. |
| Porch Designs A porch is really a place to sit, spend some time with family enjoying outdoor beauty. You can choose a porch design .. |
| Guidelines for Doors and Windows Opening in Walls Doors or Windows opening in walls are skilled part of construction in home, work are or any other structure. It needs .. |
| Kitchen renovation ,Four Important Aspects to Consider Renovation is a dreaded word because it means bringing back rigour and newness into something old. Easier said than done |
| Ceiling Design- New Ceiling Design for 2012 Ceiling design ideas can change the overall look of the room. Look at the new collection of ceiling design that gives .. |
