Home -> Forums -> Vastu -> Bedroom -> I want a house layout & design which contains one shop must and other area for h
Sun Jul 01, 2012Total posts : 1
Ramesh
Ramesh
Topic: I want a house layout & design which contains one shop must and other area for h
I want a house layout & design which contains one shop must and other area for house purpose. plot size is 34(L)* 20(W) having south face. if u have any plan send me detail or call me 9818017377
Tue Jul 03, 2012Post  #1
Swati Satija
Swati Satija
Post subject: Buy Architectural Plan Online
Dear Ramesh
GharExpert launched a very cost effective architectural plan service that is available at the link below:
  • You select a plan whose layout you like. Note down the plan code and purchase the plan.
  • Once you purchase the plan, we will contact you and send you a questionnaire through which we will understand your requirements.
  • We will assign a representative for your project and he/she will coordinate all your requirements.
  • After discussions with you, we will adjust the plan according to your exact plot size and make as many changes as you like. Our prices are based on per square feet of built area and if after changes your built area increases by more than 10% then we will change for the increased area accordingly.
  • If you also purchase guidance from Vastu expert then an independent vastu expert be assigned toyour project and he/she will review your plan and suggest changes.
  • Once the plan is finalized, we will give you dimensions as shown in the sample drawing and door window schedule.
  • If you purchase more drawings then the same will be delivered to you according to the plan finalized by you.
  • If you choose a 3-D option too, then the process works as below.
    • After completion of the architectural plans, we will recommend and send to you a few pictures/3-D models of the homes. In those pictures, we will ask you to shortlist the items of the exterior elevations. You can also send us the pictures of homes that you like. Through the existing pictures, it will be easier for you to shortlist the material and shape of exterior elevation.
    • Based on the architectural plans and your preferences, our 3-D designers will design the 3-D elevation for your home.
  • If you purchase, 3-D elevation plan then you should also purchase the 2-D elevation plan as all dimensions and levels are provided in the 2-D elevation plans. Your contractor would use the details in the 2-D elevation plan to construct your home. The 3-D pictures are there for a reference so that both you and your contractor can visualize the same thing.
Swati
Bedroom-Vastu Questions (39)
1181
Dear sir, my plot is 48*60 suggest me some design for 3 BHK, this house contain
Last answer on 7/8/2018 9:52:11 PM. by S L Gupta (Civil Engg). Forum started by Shubham Prakash
1561
3622
24feetby 81feet house plan ground floor ,dabal parking, one shop.
Last answer on 7/3/2020 11:24:29 PM. by S L Gupta (Civil Engg). Forum started by Pramod kumar
3800
Orientation of Building
Last answer on 8/6/2010 2:09:05 PM. by narayan. Forum started by pooja
2384
respected sir/mam i want designs for first floor area 20*34 ft..please suggest
Last answer on 6/11/2013 1:25:53 PM. by savita. Forum started by savita
6147
1689
area & shops ,flats
Last answer on 7/3/2020 11:49:01 PM. by S L Gupta (Civil Engg). Forum started by amol bankhele
3651
3463
2599
i wanted the design for the pillar but i dont get it
Last answer on 7/4/2020 2:44:41 AM. by paresh jadavani. Forum started by florinda dsouza
5425
Last answer on 7/3/2020 9:15:14 PM. by S L Gupta (Civil Engg). Forum started by kcp
5335
I wants windows and door design
Last answer on 7/3/2020 11:34:08 PM. by S L Gupta (Civil Engg). Forum started by Prahlad Kumawat
2363
2303
want aplot layout
Last answer on 9/25/2014 2:50:41 PM. by seema tyagi. Forum started by vipantiwari
Sir i wants a layout of polt whose size is 3150 squarefeet whose front width is
Last answer on 9/26/2014 11:24:08 AM. by seema tyagi. Forum started by vipantiwari
2467
1889
plz send me layout of duplex flate of area 1300sqft
Last answer on 1/31/2011 12:28:10 AM. Forum started by ajeet kumar
3895
Construction software
Last answer on 1/2/2021 5:22:24 AM. by DK. Forum started by tvammu
9961
2341
VATU OF FIRST FLOOR inDuplex
Last answer on 2/13/2022 6:46:20 PM. by geetika. Forum started by Anoop
1892
Home Entrance- South East
Last answer on 1/22/2022 12:39:20 AM. by S L Gupta (Civil Engg). Forum started by Jitesh Rughani
9962
Please help me if northeast corner cut is correct.
Last answer on 1/8/2022 8:14:43 AM. by Robin Goswami. Forum started by Neha
2058
Last answer on 12/21/2021 1:37:30 AM. by S L Gupta (Civil Engg). Forum started by SACHIN
2701
Last answer on 12/2/2021 6:58:04 AM. by S L Gupta (Civil Engg). Forum started by Satvinder kaur
3260
bedroom tree vastu
Last answer on 9/29/2021 7:10:55 AM. by Anil Kumar Mishra. Forum started by Samarjit Roy
6980
VAASTU FOR APARTMENTS
3158
Why one should refer to the Vastu?
Last answer on 6/2/2021 8:57:38 PM. by Deepak. Forum started by Priti Arora
4664
Last answer on 3/5/2021 2:45:15 PM. by Pavan. Forum started by anjli
2780
Children room
Last answer on 12/31/2020 2:16:24 AM. by Priti Arora. Forum started by madlika
2836
yes room is very beautiful but not ideal for indian houses
Last answer on 12/31/2020 2:05:28 AM. by juhi. Forum started by nivia
2550
map for new house
Last answer on 8/11/2020 1:03:40 AM. by S L Gupta (Civil Engg). Forum started by jassmann
7407
Last answer on 7/20/2020 11:36:14 PM. by Gunjan Utraja. Forum started by srinivas
book shelf
Last answer on 7/13/2020 3:59:55 AM. by S L Gupta (Civil Engg). Forum started by Prabha
2471
Last answer on 7/9/2020 4:06:40 AM. by S L Gupta (Civil Engg). Forum started by sarasrl
2911
nice design
Last answer on 7/9/2020 4:04:00 AM. Forum started by jaswindersingh
2169
Last answer on 7/8/2020 11:15:27 PM. by S L Gupta (Civil Engg). Forum started by dheeraj miittal
2286
Last answer on 7/4/2020 3:34:50 AM. by S L Gupta (Civil Engg). Forum started by yasothabalanr
4687
L-shaped room?
Last answer on 7/4/2020 2:27:12 AM. by bijumohang. Forum started by bijumohang
3232
apartment vastu
Last answer on 7/4/2020 2:11:34 AM. by geetika. Forum started by bobby
Why you should buy uPVC Windows by WindowMagic at GharExpert.com
Maximum Wind Resistance :Window magic Kommerling uPVC window and door systems are ideal for being installed in buildings
Orientation
Rugs
Rugs for Living Room
