Thu Mar 21, 2013 | Total posts : 1 |
| Topic: I want to built a house with stilt,ground floor
I want to built a house with stilt,ground floor |
Fri Mar 22, 2013 | Post #1 | S L Gupta (Civil Engg)
It is good, construct your dream house. What type of information do you want from us, write in detail. For construction knowledge see the gharexpert.com website that will give you lot about construction if you spent time. | |
Articles that might interest you! | | Orientation of Building To get maximum ventilation and natural light in your house, make sure the building is properly oriented. Orientation o.. | | Gharexpert can save you money during construction Do you know almost all individual home construction projects in India take more money to complete than what people ori.. | | Preliminary Works during Ground Work Entire area should be cleared of all roots, bushes, vegetation etc. for a smooth construction works. | | Which Are Various Reasons of Cracks in Buildings? Cracks can happen due to foundation movements and settlements of building, thermal movements, chemical reactions, elas.. | | Building New Home V/S Buying Builder Flat Buying a builder’s flat may be costlier for you rather than building a new home. But if you plan to make your own, you.. | | What steps are recommended for painting an existing building? It may be necessary to prepare your walls painting if they are worse and solid to remove the natural household layers .. | | Environmentally Friendly Houses An environmentally friendly house is designed and built to be in tune with its occupants, nature, environment and ecos.. | | Guidelines for Ventilation in Building Proper ventilation in building ensures sound health and good living conditions. This write-up tells you some tips for .. | | Environment Friendly Houses An environment friendly house is designed and built to be in tune with its occupants, nature, environment and ecosys | | Pool Pumps Pool pump is the most important equipment of your swimming pool. This device works with filter to maintain the cleanline | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
