I want to construct underground water tank of 6'x6'x6'. Please give cost estimat
Sun Jul 14, 2013Total posts : 4
Neeraj Sharma
Neeraj Sharma
Topic: I want to construct underground water tank of 6'x6'x6'. Please give cost estimat
I want to construct underground water tank of 6'x6'x6'. Please give cost estimate and also suggest if use of tiles is better option?
Wed Jul 17, 2013Post  #1
Dear Neeraj
          The cost of under ground water tank with RCC walls and glazed tiles on inner surface of wall,with top and bottom RCC slab is comes out app RS 50000-00
Wed Jul 17, 2013Post  #2
Neeraj Sharma
Neeraj Sharma
Thanks you Mr.Gupta. One thing to ask is RCC Walls means no bricks are required and does the estimate includes labour cost? If RCC walls does means no bricks then what is the cost difference if brick wall is used?  Is there any chances of damp/ seapage in house area? Please help as I have no knowledge of construction field and need to know before starting work.
Neeraj Sharma
Thu Jul 18, 2013Post  #3
Dear Neeraj
               In brick walls , there is possibility of dampness.In RCC walls no brick is required.The cost includes the labor charge. If you want to construct in bricks than cost will be 4
50%.
Thu Jul 18, 2013Post  #4
Neeraj Sharma
Neeraj Sharma
THANKS A LOT.
3119
5207
2483
2187
2058
2450
2634
2119
2219
3370
7232
2 lakh litre water tank
1765
Stair Grade Beam
Last answer on 3/30/2017 12:59:46 PM. by S L Gupta (Civil Engg). Forum started by Sanzana Hosen
1844
6580
6272
Water Tank Quality
13537
3967
water proofing of water tank
2175
Vastu for Water Tank
Preventive
Reasons of dampness
60
60 Tips to Save Water
