I want to contruct first floor on already existing ground floor with a plinth ar
Mon Nov 05, 2012Total posts : 0
parvathi
parvathi
Topic: I want to contruct first floor on already existing ground floor with a plinth ar
I want to contruct first floor on already existing ground floor with a plinth area of 200 sqft. The construction has 12 pillars.Can you please estimate the cost of construction of the first floor.
Last answer on 11/5/2012 5:44:56 PM. by krishna. Forum started by parvathi
2378
Spiral staircase from first ground floor to first floor
Last answer on 3/4/2015 12:37:11 PM. by satish. Forum started by satish
1919
1767
2467
1941
regarding map
Last answer on 6/24/2014 1:15:10 PM. by seema tyagi. Forum started by dr hemant isngh
2065
We have a Ground floor house already constructed some 15 years ago,and 2 floors
Last answer on 8/22/2013 10:36:36 AM. by S L Gupta (Civil Engg). Forum started by feroz khan patthan
15360
2nd floor construction
2321
5029
pls sent a suitable front elevation for 20x60 ground and first floor building
Last answer on 1/22/2022 12:11:35 AM. by bablu suthar. Forum started by naga
2912
construction suggestion needed
Last answer on 12/21/2011 9:40:34 AM. by ravi at Dalmia. Forum started by rajan
10721
Life span of RBC lintel roof
1414
want to see ground and first floor plan of it
Last answer on 6/28/2016 2:34:13 PM. by S L Gupta (Civil Engg). Forum started by s k tiwari
3622
24feetby 81feet house plan ground floor ,dabal parking, one shop.
Last answer on 7/3/2020 11:24:29 PM. by S L Gupta (Civil Engg). Forum started by Pramod kumar
1597
How much Marole required
2388
2730
2291
Preliminary
Terrazzo
Pool Pumps
Tips for Cement Paint
Tips for Oil Bound Distemper
Sewerage
Sewerage & Plumbing System
