I wish to construct a single story house using bricks and RCC roofing. Pl advise
Mon Jul 20, 2015Total posts : 1
r.n.misra
r.n.misra
Topic: I wish to construct a single story house using bricks and RCC roofing. Pl advise
I wish to construct a single story house using bricks and RCC roofing. Pl advise cement mortar ratio.
Mon Jul 20, 2015Post  #1
Various Ratios of RCC
RCC denotes Re-in forced Cement Concrete in which cement, sand and Bajri are laid with the help of mild steel. This is most important part of the structure. Generally 1:2:4 and 1:1.5: 3 ratios of RCC are used in construction work.
RCC 1:2:4
Where cement concrete 1:2:4 is used; it means 1 part of cement 2 parts of fine aggregate/coarse sand and 4 parts of coarse aggregate. This ratio of cement concrete gives high strength of cement concrete and is recommended for following works.
• For general RCC work in buildings
• Bed plates
• Lintels
• RCC shelves
• Pavement etc.
RCC 1:1.5:3
Where cement concrete 1:1.5:3 is used; it means 1 part of cement 1..5 part of fine aggregate/coarse sand and 3 parts of coarse aggregate. This ratio of concrete also gives very high strength of cement concrete and is recommended for following works.
• Structure carries in heavy loads
• Important RCC structure such as columns, beams, slabs, cantilever, Chhajja, porch, and balcony etc.
• Minimize the effects of earth quake.
• Gives more strength accordingly if Tor or Ribbed steel is used with cement concrete 1:1.5:3.
2992
1875
1702
1480
1684
9885
3087
804
3005
i wana construct a 18X14 feet hall single story .Is 9x9 column at corner os suff
Last answer on 9/19/2013 2:12:08 PM. by manishkumar. Forum started by manishkumar
2843
Last answer on 6/17/2013 5:17:52 PM. by Navneet Jharia. Forum started by g.s.rajan
2931
FLY ASH BRICKS
Last answer on 6/27/2009 12:07:21 PM. by Kranap. Forum started by mamta
4402
I would like to know How much Minimum maintain the re inforcment spacing in the
Last answer on 12/31/2020 2:22:36 AM. by Girish. Forum started by tkalaiva
4013
this is execelant front view,looking varities of front elevation for single sto
Last answer on 12/27/2020 8:48:44 PM. Forum started by Thakur Pattanaik
2585
i want to see elevation of single story bunglow
Last answer on 5/28/2013 5:05:45 PM. Forum started by Nilesh Mehta
23050
Can i have front elevation for Indian homes with single story
Last answer on 7/4/2020 3:07:35 AM. by JAI PRAKASH. Forum started by sanjeevv.verma
1606
Want a front elevation of 32* 50 floor plan single story
Last answer on 10/12/2016 11:28:31 AM. by S L Gupta (Civil Engg). Forum started by avtarbagha
15
17
Skylight
Happy
Happy New Year 2009
Happy
