Home -> Forums -> Construction -> Start Construction -> I would like to construct building with Earth quake resistence
Thu May 23, 2013Total posts : 2
ananth
ananth
Topic: I would like to construct building with Earth quake resistence
I would like to construct a building in chennai with Earth quake resistence.
Please give a brief idea.
Fri May 24, 2013Post  #1
GULSHAN RAI GULATI
GULSHAN RAI GULATI
Dear Ananth g,
Earth Quake Resistance building is basically a  RCC framed structure building
having  reinforced cement concrete  footings , columns  , beams and roof.
The columns and beams are tied up at Plinth Level , Roof Level and some times
at Lintel Level [ Tie beams ]
Outer Peripherial walls are mostly 230mm thick Brick / Block / Stone walls and  internal partition walls are generally of 115mm thick thickness.
The design of the building has  to be got done from the registered Structural Engineers with their certification for its structural stability.
Thanks.
Fri May 24, 2013Post  #2
Dear Ananth
        First you prepare the drawing with the help of architect.after it prepare the drawing for structural design, than take necessary approval from MC. prepare detail estimate and higher the contractor for construction. See the link below
3079
Stilt floor
Last answer on 7/16/2014 5:45:40 PM. by anand. Forum started by PRAKASH
1802
General question about the fees for Engineer/Arcitect/Structural Eng.
Last answer on 5/24/2013 12:17:12 PM. by GULSHAN RAI GULATI. Forum started by ananth
2619
Last answer on 4/19/2017 4:35:06 PM. by B Thakar. Forum started by tareq
3501
45465
how much cu.m of earth can excavated by machine per day
Last answer on 4/3/2021 12:46:18 AM. by prasadtvp. Forum started by sherab tenzin
3065
please send me PoP latest designs Designs I liked this design.
Last answer on 4/28/2012 11:48:24 AM. by Swati Satija. Forum started by poonam
2281
which marble and its sub category to buy
Last answer on 7/3/2020 11:36:27 PM. by JAI PRAKASH. Forum started by sushantsah
1488
I have plot in Coiambatore, I wish to construct a Commercial building Stilt park
Last answer on 5/22/2017 1:38:27 PM. by S L Gupta (Civil Engg). Forum started by R. Ramasubramanian
3425
2843
Last answer on 6/17/2013 5:17:52 PM. by Navneet Jharia. Forum started by g.s.rajan
3304
GFRC Construction
4443
lobar work quantity
2063
concrete filling
Last answer on 4/18/2014 7:54:24 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
Last answer on 10/15/2014 8:31:38 AM. by SANJAY DUSANE. Forum started by naresh
1875
3842
717
What do the likes in TikTok affect? - Why does everyone go after these likes and
Last answer on 11/3/2021 1:00:24 AM. by CrySmile. Forum started by olii fill
3623
built up area vs land area
Last answer on 7/13/2020 10:50:09 PM. by S L Gupta (Civil Engg). Forum started by cgvmp
2321
3310
How does earth quake affect the building?
The outer shell of the earth called lithosphere is broken into plates which are in constant motion, moving at about th..
Earthing
Earth Filling
Orientation
Orientation of Building
