IN independent house - min how much rcc thk required and re informcement steel spacing and size of steel
Sat Jul 10, 2010Total posts : 2
tkalaiva
tkalaiva
Topic: IN independent house - min how much rcc thk required and re informcement steel spacing and size of steel
Economical design requirment
Sat Jul 10, 2010Post  #1
Dear Tkalaiva
  The spacing and diameter of MS bars and thickness of slab are co-related with the span of the RCC slab and load to be bear by the slab where as the thickness of the RCC slab should not be less than 4’’ in any case.
Fri Mar 01, 2013Post  #2
Maharshi
Maharshi
I obliviously agree with Gupta Uncle
RCC Roof
2081
help
Last answer on 1/9/2015 12:09:16 AM. by JAI PRAKASH. Forum started by Asif
2248
2865
Steel calculation
721
2684
steel requirment
3494
4647
4330
2216
15582
2218
COST OF COLUMN PER SFT
Last answer on 5/24/2021 11:15:40 PM. by JAI PRAKASH. Forum started by Ganesh
2685
Steel Size
Last answer on 8/21/2014 12:31:17 PM. by S L Gupta (Civil Engg). Forum started by ferous
5691
1991
Residential complex
2723
can you pl discuss the disadvantages of using higrade steel such as fe 650 700 f
Last answer on 12/31/2020 2:09:55 AM. by H S Rathi. Forum started by Raman
13755
4836
Type
HSD
Precautions
Steel
Steel Roofing
