INTERNAL DOORS
Tue Nov 17, 2009Total posts : 1
Girish
Girish
Topic: INTERNAL DOORS
Internal Doors.
-    Core material
-    Solid Lipping
-    Decorative Prefinished Veneer Covering
And Solid wood Door Frame
Classic Wooden Interior Doors
Timber (pine, walnut, beech, oak ) which can be varnished and painted finish with options to have Solid Door or  Glazed panel door with toughened safety glass
Interior folding door where space is tight
Bifold (2 panel, 4 panel or 6 panel )
Veneered door -  it can be on a MDF / Chip Board / Wooden door – by applying decorative veneer on top.
Generally Molded panel doors are more made using MDF  (and more in use for cabinet doors)
Flush door -  The core is Chip board , on the top of which veneered MDF panel is fixed,
*Flush door made with HALSPAN PLANKS range now available even with Fire Rated Doors.
Tue Nov 17, 2009Post  #1
Girish
Administrator
Girish
Post subject: PANEL DOOR
PANEL STYLE DOORS using ready made chipboard blanks
A straight forward construction method
The chipboard core can be machined to simulate either flat or raised and fielded panel styles. ( limitation – two to 8)
Arched, circular, rectangular or scalloped or square shapes can be made
Perimeter edges of panels finished in hardwood , softwood or MDF mouldings
Fabrication , frame, lippings, glazing as per the design requirements
3242
I want to paint my house plz suggest the colour for internal rooms & external
Last answer on 2/15/2012 10:39:54 PM. by skycrane. Forum started by vago suzare
2368
estimation
1721
Dear All,What is the appropriate location for main Door, Kitchen and internal st
Last answer on 7/3/2011 7:13:51 PM. Forum started by RAMJEE MISHRA
2961
2111
2685
please give images for iron door in front of main wooden door,
Last answer on 11/18/2013 3:27:52 PM. by S L Gupta (Civil Engg). Forum started by nagaraja k.n.
2859
Can u pls send me price for upvc door and door frame.Thomas
Last answer on 7/4/2020 3:07:03 AM. Forum started by Thomas Rodrigues
2308
Which places are appropriate for flush doors in home?
Last answer on 7/3/2020 11:16:11 PM. by JAI PRAKASH. Forum started by kishore jain
3216
Door direction
Last answer on 7/3/2020 9:10:36 PM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
2491
door design
Last answer on 2/14/2014 4:17:10 PM. by Navneet Jharia. Forum started by chethan
2433
door design
Last answer on 11/24/2021 10:01:15 PM. by S L Gupta (Civil Engg). Forum started by chethan
2160
are iron doors expensive than pvc doors?
Last answer on 3/2/2014 5:40:13 PM. by Navneet Jharia. Forum started by neelam rathi
1770
1935
chick door
1646
1284
1412
Hello,can we make double door from flush door. door size is 38.3x 79.4 and neare
Last answer on 2/8/2017 2:23:00 PM. by S L Gupta (Civil Engg). Forum started by Ashok
2625
Vastu of the attached flat
Boyfriend/Girlfriend Vashikaran Specialist Tantrik Baba Ji 91-9056562757
Last answer on 1/6/2025 11:00:11 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:10 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:09 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:08 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:07 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:06 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:05 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:04 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:03 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:02 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:01 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:00 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 10:59:59 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 10:59:58 PM. Forum started by Pandit Sahil Sharma Ji
Panel
Panel Doors- Advantages and Disadvantages
Panel doors are quite popular in homes for various reasons. Panel doors are hard or provide more security and privacy ..
Garage
Garage door parts
Understanding garage door parts can help you in choosing the style of garage door, maintaining, and increasing the life.
Hardwood
Hardwood door
