Sat Sep 26, 2015 | Total posts : 3 |
| Topic: IPS VS BBC for open terrace
Hi All,
please advice me what waterproofing is economical and long lasting. i live in mumbai where rainfall is heavy and summers are also harsh.
Thanks in advance.
Sat Sep 26, 2015 | Post #1 | JAI PRAKASH
Join date: May 2014 | Contact Dr.Fixit They can give you many options.
Go for bitumen (Cheap) or Silicon (Expensive but best). | |
Mon Sep 28, 2015 | Post #2 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear Sir For good I am in view that
.No. | NAME OF COATING | NAME OF MANUFACTURER | NATURE OF COMPOUND | USES |
1. | Chemistic Rubberized Water proof coating | M/s Chemisol Agencies | Single
component ready to use, black color can be applied to damp surfaces.
Excellent adhesion to all building materials. (Apply Chemistic Clear
water proofer as a primer cot first) | Water proofing of terraces, basement, water tank. | 2. | Chemistic White Water proofer | M/s Chemisol Agencies | Rubberized
water proofing coating single component, white color. By adding stainer
decorative coating can be got abrasion resistant,washable. Can be used
as an under coat. Excellent adhesion to almost all building materials.
Apply one coat of chemistic clear water proofer as primer below. Dry
surface required. | Water proofing of roofs,terraces,tanks, basements. | 3. | Tarothane | M/s Choksey Chemicals | Two
component coatings are made of high quality Tar with polyurethane. Can
be used over existing Tar/Bitumen treatment . Doesnt require re-coating
year after year. No primer required for concrete surface. | Water proofing of roofs, terraces, metals/concrete tanks, toilet sunken portion, pipelines. | 4. | Mastercreet | M/s Choksey Chemicals | Polymeric modifier for cement. To be used in the ratio of 2:1 (2 cement 1 mastercreet) for water proofing coating. | Water
proofing of tanks.,To improve adhesion, flexibility, durability,
corrosion resistance , ultraviolet resistance.,For mixing in cement
paint to improve durability and prevent discoloration. | 5. | Brushbond | M/s Fosroc Chemicals | Acrylic polymer modified cementitious coating. To be applied on damp surfaces. | Water proofing of water tanks, roofs etc. | 6 | Techcoat | M/s Choksey Chemicals | Polyurethane rubber based coating.(To be applied on dry surface. No primer needed.) | Water proofing of roofs, terraces.,Tanks.Protective coating on wood.Exterior coating on walls. | 7 | Sealer Coat and Sealoxy | M/s Chitra Insultec | Polymeric compound has good adhesion with any surface . |
Water proofing of terraces, roofs and walls ,Seals all hairline cracks,
Can be tinted to any color shade., Has a thin film coating., Sealoxy
can be mixed in lime and cement paint to improve their adhesion and
durability. | |
Mon Sep 28, 2015 | Post #3 | JAI PRAKASH
Articles that might interest you! | | Roof Garden A roof garden is a garden on the top of a building. Roof gardens are becoming popular in urban areas because of limite.. | | Labor Contract vs. material contract In building construction work, there are many aspects or things to be done by building owner such as arranging drawing.. | | Porch Designs A porch is really a place to sit, spend some time with family enjoying outdoor beauty. You can choose a porch design .. | | Building Architect vs. Structure Engineer It is very important to know the difference between architect and structure engineer if you are planning to construct .. | | Bath Tubs vs. Shower cubicles in India. Fast growing trend of bathroom cubicles world over has entered in India now. Here are few points as comparison betwee.. | | Design your Office The office where we spend our most of time be careful about the functionality and comfort of office. The working condi.. | | Guidelines for Doors and Windows Opening in Walls Doors or Windows opening in walls are skilled part of construction in home, work are or any other structure. It needs .. | | Which type of chemical is recommended for the protection of dampness ? The following table expresses the type of coating recommended for the protection of Dampness: | | Which are various types of faults in electrical fitting? These are three types of faults in electrical fitting:
.Open Circuit Fault
.Short Circuit Fault
.Earth fault and .. | | Innovative designs for Small kitchen Small kitchen seems difficult to manage. In fact they are less cluttered. But it all depends on planning a small space.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
