Mon Feb 25, 2019Total posts : 1
Surinder Singh
Surinder Singh
Topic: If there is brick found in roof slab, should it be removed and patched with conc
If there is brick found in roof slab, should it be removed and patched with concrete or left as it is.
Wed Feb 27, 2019Post  #1
       1. You should remove the brick and patch it with concrete.
        2. If brick is deep in concrete and there is enough space for plaster than do not disturb the roof and do plaster.
Roof Beam crack
2324
25594
CURING TIME FOR RCC ROOF
191801
2009
4025
3263
9848
2042
I've given 3 bathrooms in a3 bhk flat. I find it 3rd bathroom not necessary.so r
Last answer on 6/3/2016 12:54:15 PM. by S L Gupta (Civil Engg). Forum started by Rsp
2339
4632
2316
3615
chair in slab steel
Last answer on 4/23/2014 8:34:50 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
2015
3445
2342
laying of roof
997
Hello, guys! I am finding an earnings calendar. Maybe you have some useful websi
Last answer on 9/8/2021 5:25:42 AM. Forum started by Simon
2080
3729
326
103
32
28
37
34
33
32
31
31
29
28
25
34
25
33
32
25
Post
Post Painting Works
Cooper
