Home -> Forums -> Construction -> Waste Water Drainage -> Importance of Proper Water Supply and Sewerage during construction
Tue Aug 07, 2012Total posts : 2
lurio ferrao
lurio ferrao
Topic: Importance of Proper Water Supply and Sewerage during construction
was interested to have two soak pits for domestic house waste from toilet & seperate for kitchen. WHAT SHOULD BE THE DISTANCE BETWEEN BOTH PITS, Can some one give suggestion
The comment above talks about the article   "Importance of Proper Water Supply and Sewerage during construction"
Tue Aug 14, 2012Post  #1
Dear ferrao
          The distance between the two soak pit is not mendatory, because the both are having waste which should be further disposed off. Th e distance of 6meter is required in case of water line from sewer line. see the link below
http://www.gharexpert.com/articles/Waste-Water-Drainage-1526/Implementation-Guidelines-Water-Supply-San-0.aspx
Fri Apr 18, 2014Post  #2
mohammad farooq
mohammad farooq
Post subject: Importance of Proper Water Supply and Sewerage d...
pls let me know if sewere line is not available then what to do while constructing the house
Waste Water Drainage-Construction Questions (25)
2072
Dear Sir,We get water supply from city corporation
Last answer on 5/27/2012 8:33:01 PM. by Raghavendra. Forum started by Raghavendra
2195
can sewerage line be lying in south west corner of house
Last answer on 3/28/2012 11:42:26 PM. by Priyanka Sharma. Forum started by vkgogra
3806
cpvc pipes v,s gi pipes
1753
Dear Sir Constructing 72x43 East facing house.Pl guide me for water supply pipe
Last answer on 9/30/2015 8:59:54 PM. by JAI PRAKASH. Forum started by Sudhir Pathak
2388
2373
2158
1837
1792
9162
What is ment of shaft in house plan what is its use and importance?
Last answer on 9/29/2021 10:49:27 PM. by S L Gupta (Civil Engg). Forum started by Shailendra Srivastava
1965
2843
Last answer on 6/17/2013 5:17:52 PM. by Navneet Jharia. Forum started by g.s.rajan
5056
1457
I have the waste water (Sewerage ) in the South west corner of my house.The buil
Last answer on 2/23/2011 7:18:13 AM. by R S Nambi. Forum started by R S Nambi
3268
3129
Importance of Water
2221
water supply
2701
Last answer on 12/2/2021 6:58:04 AM. by S L Gupta (Civil Engg). Forum started by Satvinder kaur
2031
whats remedy fr wall dampnass
Last answer on 2/25/2022 7:03:51 AM. by helloaarti21. Forum started by rakesh chopra
3292
2766
2388
Sewage and drainage lines
2001
please help....slow draining in the bathroom
Last answer on 7/4/2020 2:24:02 AM. by mvnisha. Forum started by mvnisha
2350
Traps - Types and Uses
Last answer on 7/3/2011 1:35:26 AM. by S L Gupta (Civil Engg). Forum started by SHAMS
Importance
General
Sewerage
Sewerage & Plumbing System
Checklist for Plumbing
