Home -> Forums -> Construction -> Water -> Importance of Water
Importance of Water
Mon Mar 02, 2009Total posts : 1
nethra
nethra
Topic: Importance of Water
 In apartment, with many floors , If storage water like Swimming pool is located  in front of the house(centric) , Is it good to be in centre ? And what are the solutions to avoid negative effects from this?
Tue Apr 21, 2009Post  #1
yogi
yogi
Post subject: Location of Swimming Pool
Your topic is contradictory as you say “Storage water like swimming pool” is located in front of house. Swimming pool can not serve the purpose of storage water because the water in swimming pool can not be used for household purposes and it should be changed regularly.
Where to construct swimming pool?
Swimming pool should be constructed at the side of apartment but not in the middle of house or apartment because the middle space is used for parking and road etc. If swimming pool is constructed in the middle of apartment or in front of the house, the following safety measures should be adopted.
Safety measures to construct swimming pool
  • It should be fenced so that children may not fall into the pool either by ignorance or accidentally.
  • The path leading to swimming pool should have doors with alarms under lock and key. The key should be out the reach of children.
  • Don’t place tables and chairs near the fence of swimming pool to prevent children climb to the pool area?
  • Don’t leave children unsupervised near pool especially during gathering.
9162
What is ment of shaft in house plan what is its use and importance?
Last answer on 9/29/2021 10:49:27 PM. by S L Gupta (Civil Engg). Forum started by Shailendra Srivastava
2504
2701
Last answer on 12/2/2021 6:58:04 AM. by S L Gupta (Civil Engg). Forum started by Satvinder kaur
3370
1662
Is there any structural importance to sunshade?
Last answer on 11/3/2015 11:49:30 PM. by JAI PRAKASH. Forum started by Techman
3157
Basement waterproofing
6414
2180
pile work
5056
3968
water proofing of water tank
2543
water softner
2388
6272
Water Tank Quality
2792
Last answer on 7/3/2020 11:53:31 PM. Forum started by mamta
3119
2072
Dear Sir,We get water supply from city corporation
Last answer on 5/27/2012 8:33:01 PM. by Raghavendra. Forum started by Raghavendra
3803
2766
3177
Sump construction
2139
Question Regarding Borewell
1967
Over Head Water Tank
2756
Salt water
10179
2494
1887
water tank motor capacity
2754
Submersible pump - Bore
2358
2548
Water for Construction
Importance
Feng Shui- Meaning and Relevance in the real estate market
Fengshui means the Law of Heaven and Earth. Feng means wind and Shui means Water. It believes in the balance of yin an..
Bathroom Ventilation
Bathroom ventilation is very essential for good health and contents of the house. It is applied to get rid of heat, hu..
60
60 Tips to Save Water
Vastu for Water Tank
Rain
Rain Water Harvesting
Preventive
Garden
Garden Fountain
Adding a fountain to your garden will invite birds and butterfly to visit your garden. The sound of water running can ..
