Home -> Forums -> Construction -> Start Construction -> Industrial RCC
Industrial RCC
Fri May 24, 2013Total posts : 3
shikha Chetal
shikha Chetal
Topic: Industrial RCC
What is the rate of RCC construction for industrial building ?
Fri May 24, 2013Post  #1
Dear Sikha
         The rates of RCC is derived with the cost of cement, coarse sand, coarse aggregate i.e. bazri or stone chippings 6mm to 20 mm, labor for centering and shuttering and also include the hire charges of shuttering required for the component to be constructed. It also include the cost of MS steel used.
The materials used in RCC is depend on the ratio used i.e. 1;2;4 or 1;1.5;3 so on.Quantity of steel is different in each component such as in column, beam, slab and facia etc. The rates of material is also differ from city to city.
 So calculate rate as per detail given above by applying your city rates of materials.
Mon May 27, 2013Post  #2
shikha Chetal
shikha Chetal
Post subject: parking shed
hello,
Can you let me know what will be probable cost per sq feet for parking  shed
1) with good material
2) with avg material
in Maharashtra
Tue May 28, 2013Post  #3
Dear Sikha
       Pleas tell us what type of roofing material of shed you want to lay i.e. galvanized iron sheets or AC sheets or plastic sheets,height of shed and size of shed and any side of shed is covered by brick wall.All the specifications are related with cost. Better if drawing is framed.
2289
vastu for industrial project
Last answer on 7/19/2010 7:09:38 PM. by sabina vanjani. Forum started by harbans singh sekhon
2041
Soak pit location in industrial plot
Last answer on 5/21/2019 1:35:08 AM. by JAI PRAKASH. Forum started by navin
2024
Industrial Maintenance
Last answer on 5/14/2021 10:32:21 AM. by S L Gupta (Civil Engg). Forum started by MarianneRolfe
3652
1702
10572
cost of industrial shed
Last answer on 7/23/2013 11:20:11 AM. by S L Gupta (Civil Engg). Forum started by aakesh
5813
Industrial shed construction
Last answer on 1/8/2022 4:18:30 AM. by S L Gupta (Civil Engg). Forum started by shikha Chetal
2609
Last answer on 4/18/2017 1:11:37 PM. by MarianneRolfe. Forum started by MarianneRolfe
2155
What would be a very rough cost for constructing an industrial shed (just outter
Last answer on 1/16/2016 1:09:41 PM. by Akshay Wadke. Forum started by Akshay Wadke
6381
kota Stone Roofing
3754
2808
2918
Lumpsum constraction cost of smal home in RCC lock
Last answer on 1/18/2022 2:25:39 AM. by S L Gupta (Civil Engg). Forum started by neelkanth purohit
35211
3803
9894
2992
2720
3312
2236
2312
2061
Type
How To Repair Cracks
Iron
Iron Sheet Roofing
ACC
ACC Sheet Roofing
