It's very urgenti am constructing a house in hyderbad.East face plot(36*50)36 wi
Mon Sep 27, 2010Total posts : 3
varala prasad babu
varala prasad babu
Topic: It's very urgenti am constructing a house in hyderbad.East face plot(36*50)36 wi
It's very urgenti am constructing a house in hyderbad.East face plot(36*50)36 width and 50 depthAs per the design wash area is coming behind the pooja room.normally in hyd pooja room and kithen are adjacent to each other, due place problem we are giving wash area behind the pooja room is it ok as per vastu is my question hereplease give me your valuable suggestions
Tue Sep 28, 2010Post  #1
kishan prabhakar
kishan prabhakar
Post subject: try to avoid as far as possible
Dear Varala Prasad Babu,
I understand that due to space problem u r giving the wash area behind the pooja but Try to avoid any waste water pipe touching the walls of the pooja. see untill unless you are using the area as a wash room only with out touching the walls with sanitary pipes and sanitary fittings it will be good. see if u can get it redesigned and place the wash away form the pooja room.
one more alternative suggestion is create a cavity between the wash room and pooja room wall by construction an wall by leaving 6" to 9" space so that the pooja will become independent.
Tue Sep 28, 2010Post  #2
Varala,
If you are talking about the Vastu aspect then the Pooja room should be in North/Northeast or East
Sabina Vanjani-Vastu Analyst
Fri Oct 01, 2010Post  #3
madhusudan
madhusudan
dear varala,
A Cavity between pooja room and wash room by leaving space as per convienence will make pooja room independent .
2943
3275
my plot east 36 north 50. north and west 2 side road, i want 4 side open pls sug
Last answer on 11/3/2014 5:15:20 PM. by Ashok. Forum started by ravi
8317
Can u please give me some house plans for a 200 sq yard plot of 36 * 50 size...
Last answer on 6/24/2018 11:27:52 PM. by S L Gupta (Civil Engg). Forum started by shwetha
2372
4012
36' x75' east north facing
Last answer on 6/24/2018 11:29:57 PM. by S L Gupta (Civil Engg). Forum started by Ajesh k singla
1630
ihave openplot around 36*17 North facing plot ineed toconstruction
Last answer on 9/30/2016 1:09:24 PM. Forum started by Mohan
4427
15/36 HOUSE PLAN EAST
Last answer on 1/8/2018 11:06:46 PM. by S L Gupta (Civil Engg). Forum started by Ramesh Kumar Mishra
2194
Hello,My plot dimensions are 36 feet by 75 feet south facing, please suggest me
Last answer on 7/2/2020 10:07:43 PM. by Gore. Forum started by Gore
1424
Hello, My plot dimensions are 36*36 west facing, already roof completed, i want
Last answer on 8/31/2016 10:47:13 AM. by S L Gupta (Civil Engg). Forum started by krishna
2307
I have east fase 25ft front 36 ft with plot I want 2 bed room (one attached bot
Last answer on 7/2/2020 10:06:26 PM. by seema tyagi. Forum started by sp dubey
1570
I have 22*36 west facing plot. Please give me a naksha
Last answer on 3/14/2017 12:07:07 PM. by S L Gupta (Civil Engg). Forum started by Ravi
5789
32*36 North face naksha
Last answer on 7/9/2020 10:07:58 PM. by S L Gupta (Civil Engg). Forum started by Vivek
6316
I need floor plan for my house - west Facing (36Width - 52 length)
Last answer on 5/14/2010 1:57:41 PM. by amit yadav. Forum started by rajender
1051
Please suggest me duplex house G 1 floor plan and size of my property is 36*75
Last answer on 1/29/2019 12:48:24 AM. by S L Gupta (Civil Engg). Forum started by bharath
3502
house plan 36*75 sq feet east face 3bhk
Last answer on 12/7/2014 10:57:44 PM. by Navneet Jharia. Forum started by navjot
1914
show me naksha
Last answer on 7/5/2021 8:23:30 AM. by JAI PRAKASH. Forum started by sukhdev singh
1673
hello sir, I have a 35*36 plot please suggest design for 3 bed room and one dra
Last answer on 7/2/2020 10:06:40 PM. by S L Gupta (Civil Engg). Forum started by SATYAM SINGH
21010
House Plan for 18 Feet by 36 Feet plot (Plot Size 72 Square Yards)
Last answer on 7/16/2015 10:36:34 PM. by JAI PRAKASH. Forum started by kishore
