Home -> Forums -> Construction -> Start Construction -> Item rate Constructions better than square feet rate
Fri Jul 24, 2015Total posts : 3
BUILDMARK CONSTRUCTIONS
Topic: Item rate Constructions better than square feet rate
Item rate constructions is good than square feet rates, People have developed this square feet rate trend unaware of the pros and cons, Many civil contractors who are not qualified started contracting even Masons and Mistrys too started contracting, clients looking for cheap constructions or in hope of getting price fall prey to these unprofessional civil contractors and later they repent when they face problems after construction, Please act wise and hire only and only qualified engineers.
Sanjay Nagar
Bengaluru
7760685123
Fri Jul 24, 2015Post  #1
       Thanks for suggestion. You are right that unqualified contractor who are not able to calculate different items prefer sq feet rates. But the same problem is with house owner. In India we people wants to save a small money for engineering events but repent after words.
Fri Jul 24, 2015Post  #2
Its good to go with square foot rate but mentioning all the items in details to overcome those problems.
Tue Jul 28, 2015Post  #3
Post subject: Mr. Sanjay Nagar, You are true.
Dear mr, Sanjay Nagar,
It is true that many un-skilled contractors are working in the field.
 But sometimes owner also insist upon contractor to quote rates in sq ft.. Because they (owners) dont have time to calculate every item. they think it is a burden and headache.
2512
2797
35211
2525
1810
Last answer on 1/27/2016 12:04:33 PM. by S L Gupta (Civil Engg). Forum started by A Ghosh
11587
2362
3911
rate analysis
Last answer on 4/17/2021 1:15:59 AM. by S L Gupta (Civil Engg). Forum started by chethan
3415
SOR
Last answer on 12/30/2021 10:26:27 AM. by S L Gupta (Civil Engg). Forum started by navneet
18382
3016
Rate of construction of 1st floor of private house 1000sft. in kolkata
Last answer on 2/2/2016 6:19:47 PM. by S L Gupta (Civil Engg). Forum started by A Ghosh
2035
What is the construction rate of commercial project in Pune right now.
Last answer on 1/25/2017 12:49:44 PM. by S L Gupta (Civil Engg). Forum started by Ritesh Bodake
2406
MY CONTRACTOR IS CHARGING THE SAME RATE OF CONSTRUCTION FOR GROUND AS WELL AS FI
Last answer on 8/22/2013 12:12:50 PM. by Ahmed. Forum started by K S SHYAM SUNDER
2041
estimation
Last answer on 4/30/2013 12:39:09 PM. by S L Gupta (Civil Engg). Forum started by dan
2522
Industrial RCC
Last answer on 5/28/2013 10:17:13 AM. by S L Gupta (Civil Engg). Forum started by shikha Chetal
4108
3651
5060
946 squre feeti estimate in kolkata
Last answer on 9/8/2014 9:14:34 PM. by JAI PRAKASH. Forum started by jitendra
2118
also want to know the rates of double bed that carpenters charge in lucknow
Last answer on 9/3/2014 2:45:28 AM. by JAI PRAKASH. Forum started by neelam rathi
3312
2312
Through
What is acre
KITCHEN
"KITCHEN"THE POWER HOUSE
SOUTH-EASTCORNER IS SUPPOSED TO BE THE PLACE OF LORD AGNI,GOD OF FIRE.
Importance
