Its again a common query! Planning to build a house independent house (G 1) in M
Sun Sep 26, 2010Total posts : 3
Venkata Ram
Venkata Ram
Topic: Its again a common query! Planning to build a house independent house (G 1) in M
Its again a common query! Planning to build a house independent house (G 1) in Madambakkam. Looking for reasonable
Mon Sep 27, 2010Post  #1
Dear Venkata ram
1. You should contact good architect with your plot details and your requirements to be full fill your needs at the time of framing the drawing.
2. When plan of the house is cleared by you than it is necessary to prepare structural drawing showing foundation detail, column details, beam details and slab detail including provision of anti earth quack measure.
3. Cost detail estimate should be prepared so that every thing is clear to you i.e. what quantity & quality of material is required and you should get step wise cost so that at the time of allotting to work to the contractor you should know what is actual required what the contractor demanding.
4. Hire the contractor on the basis of plan, structural drawing and estimated quantity and cost.
You should contact support@gharexpert.com for every type of quarry and they have all type of service and supply you as many tips and help you required from time to time.
Further more there are links for start construction if you go through it there are many articles which will give all answer to your quarry including how to hire contractor etc and other link give you specimen of detail cost estimate and tips relating to your plan etc.
http://www.gharexpert.com/category/1326/Start-Construction-0.aspx?PL=2&Estimator=
 http://www.gharexpert.com/include/sample_estimate.pdf
Mon Sep 27, 2010Post  #2
Venkata Ram
Venkata Ram
Hi
I am looking for an architect who can plan/build/supervise constuction in reasonable fee.
My flat is 60x40 - south facing. Its not big budget one, being an NRI i cannot spend much time into it personally.
Thanks,
Venkat
Mon Sep 27, 2010Post  #3
Post subject: Please supply the following information
Dear  Mr. Venkata,
Thank you for contacting GharExpert for Architectural services. For initiating it further, Can you please send me the answers of the following questions:
1) Do you want vastu compliant designs?
2) What is your budget?
3) Which type of elevation do you like? Modern, Ethnic, Contemporary,etc.
4) Where is the plot located? Where are you located?
5) What is the area of the plot? what is the coverage area?
6) How many floors are you planning to build?
Please send me answers asap so that we can proceed further.
Gunjan
Product Manager
GharExpert.com
6147
2400
2159
hai.i want a 1000ft house and have 3 attached room kitchen,hall,prayer room,1 co
Last answer on 7/3/2020 11:48:50 PM. Forum started by raajklbm
7842
3635
1726
our house is 1300sqft say the plan how it can be built
Last answer on 7/12/2009 2:37:32 PM. by Priti Arora. Forum started by sonali
843
I want to a resident house plans east facing East to west 24feet and south to No
Last answer on 8/13/2020 4:15:16 AM. Forum started by Manash Prusty
2615
house layout on 40*40 east facing site
Last answer on 9/9/2011 2:11:24 PM. by kawalnain kaur. Forum started by anilpande
1561
How utilise the common space of 4 plots for 4 independent villas
Last answer on 7/3/2020 11:47:13 PM. by S L Gupta (Civil Engg). Forum started by Mujtaba
1779
sir.iam in tamilnadu.we started to plan build new house in 900 sq.ft.i need some
Last answer on 7/27/2016 2:34:54 PM. by Beenu Phogat. Forum started by madhu
a plot of 15×60 two room set + drwing+ lobby
Last answer on 5/13/2016 10:15:46 PM. Forum started by Sanjay arora
8190
Last answer on 7/3/2020 9:42:30 PM. by Beenu Phogat. Forum started by Prabhakar
2768
Improvisation of Housing Board House
Last answer on 8/17/2012 12:16:55 PM. by Gunjan Utraja. Forum started by MUKESH MISHRA
1961
how to do gas piping for a residential ground floor independent building should
Last answer on 12/26/2011 7:59:32 PM. by S L Gupta (Civil Engg). Forum started by elizabeth
5166
Main door
Last answer on 9/21/2010 12:54:11 PM. Forum started by get2kamesh
2490
5811
17
Orientation
Orientation of Building
Environmentally
Environment
Environment Friendly Houses
