Mon Dec 01, 2014Total posts : 1
hemant
hemant
Topic: Kindly suggest the columns size/TMT nos/size for maximum distance of 16ft betwee
Kindly suggest the columns size/TMT nos/size for maximum distance of 16ft between two columns for 2 storey building?
Tue Dec 02, 2014Post  #1
Dear Hement
       The size of column and steel bars can be designed according to plan of the building. Require both side distance for loading calculation.
8965
Last answer on 9/11/2020 2:17:26 AM. by hemant. Forum started by hemant
15780
6440
Column placement for house
Query
Last answer on 10/30/2014 6:53:45 PM. Forum started by hemant
2243
3134
2421
start construction Steel use
65238
6548
2718
4132
Last answer on 7/3/2020 10:23:02 PM. Forum started by V.BASKER
Column sizes for Individual House with G+2 design
Last answer on 7/12/2016 1:46:04 PM. Forum started by Venkat
1966
Dear Sir,Can you please tell me the size of the column and footing for individua
Last answer on 11/25/2020 5:27:11 AM. by Venkat. Forum started by Venkat
2843
Kindly send a new kayout for 25×30 plot size
Last answer on 7/3/2020 10:34:14 PM. by seema tyagi. Forum started by rajeeva
9001
9225
pillar size in distacce
3017
Right size cupola
