Home -> Forums -> Interior -> Kitchen -> Kitchen Cabinets
Kitchen Cabinets
Wed Feb 24, 2010Total posts : 15
madhuri
madhuri
Topic: Kitchen Cabinets
living in vijayawada,how much will these modular kitchens cost
The comment above talks about the article   "Kitchen Cabinets "
Wed Mar 03, 2010Post  #1
Ajit Tareeka
Ajit Tareeka
Post subject: Not possible to calculate the cost
Actually cost of modular kitchens depend on the various factors such as
1) Branded or Local
2) Material
3) Area of the Kitchen
Now there are pros and cons of for choosing the local or branded.
Pros and cons of Branded kitchens:
1) Very Expensive
2) May not use the durable material
3) Design kitchens according to international cooking style
4) Must get the 100% workmanship in finishing as they use the machineries to make the kitchens.
Pros and cons of  kitchens made by local manufacturers:
1) Very Inexpensive
2) More chances of getting the durable material
3) Design kitchens according to Indian cooking style
4) would not get the workmanship in finishing as they have a manual process to make the kitchens.
Sat May 15, 2010Post  #2
Prebhat
Prebhat
Post subject: Kitchen Cabinets
Kitchen in my home is in NORTH EAST direction which is not good according to FENG SUI and no possibility to change the direction. Can anybody suggest any remedy to avoid the negative aspect of the direction
Tue Mar 22, 2011Post  #3
CMoss
CMoss
I WANT TO KNOW THE PRICE OF EACH MODULAR KITCHEN?
Wed Mar 23, 2011Post  #4
Nikita
Nikita
Hello Sir,
Its totally depends on the area of the kitchen after that it will depend on no. and size of the cabinets. You should go to nearest hardware’s shop they will suggest you better.
Regards:
Nikita.
Wed Mar 23, 2011Post  #5
Hanumanth Kumar
Hanumanth Kumar
Hi, i would like to know whether the cubbords for the kitchen can be made up of new wood, if so, what are the advantages and disadvantages with new wood, my builder is suggesting these.
Thank you,
Cheers
Thu Mar 24, 2011Post  #6
Nikita
Nikita
Post subject: New Wood Advantages
Hello sir,
Yes, the cupboards can be made of New Wood. New wood include many advantages like highly resistant to water, insects, termites, and weather, more durable than other wood.
Regards:
Nikita.
Thu Mar 24, 2011Post  #7
Hanumanth Kumar
Hanumanth Kumar
Thank you very much Ms.Nikita.
In this context i would also like to know about the main doors & windows.
We are planning to buy teak wood for this. I see so many varieties of teak wood is available in the market. Which one to choose & the advantages in choosing the same.
Also whether to paint the doors and windows or to go for the polishing them & the adv & disadv for the same.
This would help me a lot in this wooden section.
Thanks & Best Regards
Hanumanth
Thu Mar 24, 2011Post  #8
Nikita
Nikita
Post subject: Doors and windows.
Hello sir,
Teak wood is a better option than other for doors and windows, as teak is a hardwood and popular for its durability and long life.
About paint and polish you should go for the polish as I think because when you are opting the teak, the polish is better as it doesn't overlap its neutral surface.
Regards:
Nikita.
Thu Mar 24, 2011Post  #9
Hanumanth Kumar
Hanumanth Kumar
Post subject: Doors & Windows
Hi Nikita,
Thank you very much for your advice on teak, but how about the variety to choose with either burma teak etc. Also if u can send me some main door designs that will help me a lot.
Hanumanth
Fri Mar 25, 2011Post  #10
Nikita
Nikita
Post subject: Teak wood Varieties
Hello Sir,
Well it would be better if you can tell me which variety available to you, so that I can tell you more superior quality. Please let me know how much types of  teak available.
Regards:
Nikita.
Sat Nov 24, 2012Post  #11
Hidayath
Hidayath
Need some stair case designs which is suitable for 14' length area with windows on the wall
Wed Aug 28, 2013Post  #12
Sheetu Gupta Naib
Sheetu Gupta Naib
Hello Sir, We have a 2X3ft space in our kitchen. We are willing to build a cabinet there which can hold most of our crockery. Do you have any suggestion for this?
Mon May 05, 2014Post  #13
Nishikant Pathak
Nishikant Pathak
What is the per RFT rate of kitchen trolleys & what is per SQFT rate of cabinets?
Tue Jun 09, 2020Post  #14
henry
henry
I agree with ajit's rply. But if you decided any budget for spend on your kitchen renovation than you will consult with your service provider.
Tue Jun 16, 2020Post  #15
Kitchen cabinets are the built-in furniture installed in many kitchens for storage of food, cooking equipment, and often silverware and dishes for table service.
As commonly used today, the term kitchen cabinet denotes a built-in kitchen installation of either a floor or a wall cabinet. Typically, multiple floor cabinets are covered by a single counter and floors and walls are not accessible behind and under the cabinets.A single piece of furniture incorporating storage and work surfaces.
Kitchen-Interior Questions (39)
13969
for kitchen cabinets what type of wood - MDF, HDF, PLYWOOD , is better
Last answer on 7/3/2020 11:24:20 PM. by S L Gupta (Civil Engg). Forum started by ganesan
2456
sir i want to design my kitchen cabinet in L shape
Last answer on 2/18/2013 1:28:33 PM. by S L Gupta (Civil Engg). Forum started by sn bharti
7092
what wood should be used for kitchen cabinet shutters.
Last answer on 3/12/2021 11:24:15 PM. by leelindsey. Forum started by neelam rathi
10905
plywood, mdf, or hdf boards are best for kitchen cabinets?
Last answer on 9/20/2016 11:01:27 AM. by S L Gupta (Civil Engg). Forum started by Binita
30101
Cost calculation for Wardrobe Cabinets
Last answer on 7/4/2020 2:32:12 AM. by Deepan Rajan. Forum started by sujaivilson
25228
Best Color Combination for Modular kitchen Cabinets and walls
Last answer on 7/4/2020 3:51:00 AM. by basil. Forum started by raghuam
2271
can u pls tel me the material of kitchen cabinet????
Last answer on 3/29/2011 9:13:26 PM. by sudhakar. Forum started by rupali
4116
kitchen cabinet
Last answer on 9/3/2020 3:07:17 AM. by johnbritto. Forum started by sn bharti
2686
kitchen cabinet finish
Last answer on 7/3/2020 10:22:28 PM. Forum started by Sangita
3185
Shutter material options for Kitchen Cabinets & Wardrobes
Last answer on 7/22/2014 4:23:17 AM. by JAI PRAKASH. Forum started by Kamani
1887
kitchen Cabinets
Last answer on 12/17/2015 2:51:28 PM. by JAI PRAKASH. Forum started by ARVIND GOYAL
1866
Material for Kitchen cabinet
Last answer on 8/8/2017 11:55:13 AM. by dcpl. Forum started by Ahmed
1588
plywood or cladded alluminium material for kitchen cabinets
Last answer on 7/3/2020 10:22:40 PM. by S L Gupta (Civil Engg). Forum started by Pankaj
3191
Kitchen Accessories
Last answer on 5/27/2013 2:33:49 PM. by David hussy. Forum started by Sangeet Sachdev
2036
Hello friends.. I wanted to know the various material used for making kitchen ca
Last answer on 1/27/2011 6:10:13 PM. by ranjeetsaini. Forum started by sreema
1470
Dear sir,what is better, a laminated ply wood or cladded aluminium for kitchen c
Last answer on 10/20/2016 12:38:33 PM. by S L Gupta (Civil Engg). Forum started by Pankaj
12485
can i make wardrobes with marble shelves and acrylic doors?
Last answer on 3/25/2014 4:27:59 PM. by Abhishek Garg (Builder & Engineer). Forum started by Mrs Francis
3457
Last answer on 2/4/2022 11:19:50 PM. by Vaasku. Forum started by jayakrishnan
2093
how to decorate a kitchen
Last answer on 7/3/2020 10:18:10 PM. by Satvinder kaur. Forum started by Satvinder kaur
2858
modular kitchen
Last answer on 2/23/2022 4:38:18 PM. by JAI PRAKASH. Forum started by Anu
2799
Modular kitchen in chennai
Last answer on 2/19/2022 2:12:28 AM. by Sally. Forum started by brandoo
3457
2911
Last answer on 1/21/2022 6:49:43 PM. by JAI PRAKASH. Forum started by Suveera
6818
Kitchen Ventilation
Last answer on 1/19/2022 2:55:03 AM. by sugantha. Forum started by sukamalroy
3428
Kitchen Island
Last answer on 1/5/2022 2:57:02 AM. by Mike Stanley. Forum started by tiwari_p_k
2841
Last answer on 1/5/2022 12:58:49 AM. by Misato Katsuragi. Forum started by Padmanaban
7310
Modular Kitchen
Last answer on 11/30/2021 12:56:09 AM. by axelbach. Forum started by Veena Gil
2927
Kitchen Sink
Last answer on 11/30/2021 12:21:26 AM. by Anjleen. Forum started by Sasikala R
2490
Introduction
Last answer on 10/23/2021 8:23:11 AM. by S L Gupta (Civil Engg). Forum started by davidraju
3661
Small Space Kitchen
Last answer on 9/15/2021 5:01:17 AM. by KVSN RAJU. Forum started by Shital Miriyala
2663
Thank you for all you do
Last answer on 7/19/2021 5:14:13 AM. by Amit Hasija. Forum started by raghav
2872
Kitchen Design Ideas
Last answer on 5/18/2021 7:44:04 PM. by rafi. Forum started by b.arunaseshan
2550
'island' counter in kitchen
Last answer on 1/2/2021 5:27:46 AM. by S L Gupta (Civil Engg). Forum started by Shashi Panwar
Kitchen Door
Last answer on 1/2/2021 5:22:53 AM. by S L Gupta (Civil Engg). Forum started by K. Basu
2540
Last answer on 1/2/2021 5:22:28 AM. Forum started by batambuze abdu
3349
Last answer on 12/31/2020 2:45:52 AM. by juhi. Forum started by ruchika jain
2626
How much would be the approximate cost of setting up a kitchen like this?
Last answer on 12/31/2020 2:40:21 AM. by ranjeetsaini. Forum started by debashish
3952
Last answer on 10/11/2020 7:21:30 AM. by S L Gupta (Civil Engg). Forum started by maruthi prasad
3285
Kitchen modular size 8*8 fit
Last answer on 10/11/2020 7:13:57 AM. by JAI PRAKASH. Forum started by Hitendra singh bhadoria
Kitchen Cabinets
Modern
Modern Kitchen
You can offer modern style to your kitchen by adding sleek and stylish appliances of stainless steel, granite and lime..
Kitchen Accessories
Kitchen Storage Ideas
Modular
The kitchen redesign is a fantastic initiative to ensure the health of family members. It needs fresh and vigilant con..
Kitchen Furniture
As kitchen is the heart of your home, do you think is it organized? Is it functional and easy? Just try to put the fur..
Bathroom Cabinets
Kitchen Remodeling Ideas
Kitchen Backsplash
