Home -> Forums -> Interior -> Kitchen -> Kitchen Lighting
Kitchen Lighting
Mon Jul 05, 2010Total posts : 6
alok jain
alok jain
Topic: Kitchen Lighting
please inform what material to use for kitchen ceiling ,so that it can be cleaned easily when it becomes oily or dirty.
The comment above talks about the article   "Kitchen Lighting "
Mon Jul 05, 2010Post  #1
Richa Shangvi Interior decorator
Post subject: You should install
I think you should install chimney and exhaust fan in the kitchen first so that your kitchen  would be kept oil free. Oil can only be removed withe some type of cleansing material. But you cannot use it on the lights. You can only clean the light with dry cloth. So please get the chimney installed in your kitchen. It is very essential if you frequently cook oily food.
Wed Jul 07, 2010Post  #2
modernplasticsco
modernplasticsco
Post subject: kitchen ceiling
use PVC foam sheets its a ideal substitute of ply wood but can be washed with
water/ soapy water also. NO colour required if you like white or you can paint any of your choice.NO TERMITES And no maintenance. I have used the same in my kitchen ceiling.
Its self extinguishing also ( less fire problem )
easy available if you have any problem contact me.
Sat Jul 10, 2010Post  #3
arisyap
arisyap
Exhaust fan is really important to the kitchen. It will clear the smell and the smoke which will cause the dirt on your ceiling. Check this price comparison shopping site. They have exhaust fans as well as different home lighting and  light fixtures. You can choose from different brand and stores.
Tue Jan 24, 2012Post  #4
manisha
manisha
Post subject: Kitchen Lighting
is false ceiling preferred in kitchens?
Thu Jul 12, 2012Post  #5
Ar. Manoj Ralen
Ar. Manoj Ralen
False ceiling as such does not pose a problem in kitchen. You may want to avoid coves in the kitchen as they are harder to maintain and dust accumulates in them over time. But a plus minus design in ceiling would give you a lot of design options.
Wed Jul 18, 2012Post  #6
davidraju
davidraju
Plastic ceiling tiles are a good choice for kitchens, because they're easily wiped clean. They come in many different styles and finishes, including metallic finishes such as copper, brass and silver.
Kitchen-Interior Questions (39)
5452
Best branded and economical Lights for false ceiling in various rooms...
Last answer on 8/23/2012 6:04:51 PM. by Ravi. Forum started by raghuam
2585
modern lighting
Last answer on 3/19/2015 12:34:01 AM. by JAI PRAKASH. Forum started by electricalproducts
1970
Mistakes to Avoid When Remodeling Kitchens
Last answer on 6/24/2015 10:47:23 AM. by SharonHarris. Forum started by SharonHarris
2796
wherei can get this light (dog showpice with light)
Last answer on 5/28/2021 11:36:38 PM. Forum started by himashree
2137
BUT I WANT A LITTLE SIMPLE DESIGN IN MAROONISH RED AND GOLDEN YELLOW WITH SPOT L
Last answer on 3/2/2012 5:07:23 PM. Forum started by DORIS
2169
We are planin to put light lavendr color in childrn bedroom is it ok
Last answer on 7/3/2020 10:53:46 PM. by S L Gupta (Civil Engg). Forum started by Jassi
2490
is these lights fixed inside the wooden boxes?
Last answer on 3/3/2011 9:03:23 PM. by Nenni. Forum started by meenu
1939
About Lighting, nice to be seem
Last answer on 7/15/2011 3:56:14 PM. Forum started by sriramkumar
1863
can combine colours light green,wine and blue.if not your suggestion
Last answer on 9/8/2011 11:14:07 PM. Forum started by der
2055
what is the name of this plats and can thay survive without sun light
Last answer on 2/16/2014 9:45:06 PM. by Gagandeep. Forum started by shoaib
1850
please send details of crystal lighting.
Last answer on 5/9/2010 3:00:05 AM. by priya. Forum started by jazz
2926
Skylights
Last answer on 12/31/2020 2:07:37 AM. by Rajan. Forum started by hemapradeep
2219
Tips for Bed Room Lighting.
Last answer on 10/13/2012 11:48:53 AM. by S L Gupta (Civil Engg). Forum started by shivendra
1892
anew model home lights sho
Last answer on 2/16/2013 1:16:47 PM. Forum started by janakiram
1965
position of lights for the dressing table
Last answer on 2/24/2013 7:44:12 PM. Forum started by anand
3347
best ceiling LED LIGHTS FOR NEW HOME IN HARYANA CONSIDERATION VOLTAGE FLUCTUATIO
Last answer on 7/4/2020 3:58:43 AM. by Sushant. Forum started by sanjeev tiwari
1771
hi im new home plan frent 36 light 25
Last answer on 7/3/2020 10:19:19 PM. by S L Gupta (Civil Engg). Forum started by sandeep
3028
I have a Kitchen of 6'' * 10"" Plx suggest some kitchen designs
Last answer on 7/3/2020 10:48:15 PM. by Nisha Batra. Forum started by Sarbani Biswas
2858
modular kitchen
Last answer on 2/23/2022 4:38:18 PM. by JAI PRAKASH. Forum started by Anu
2797
Modular kitchen in chennai
Last answer on 2/19/2022 2:12:28 AM. by Sally. Forum started by brandoo
3457
Last answer on 2/4/2022 11:19:50 PM. by Vaasku. Forum started by jayakrishnan
2910
Last answer on 1/21/2022 6:49:43 PM. by JAI PRAKASH. Forum started by Suveera
6818
Kitchen Ventilation
Last answer on 1/19/2022 2:55:03 AM. by sugantha. Forum started by sukamalroy
3428
Kitchen Island
Last answer on 1/5/2022 2:57:02 AM. by Mike Stanley. Forum started by tiwari_p_k
2841
Last answer on 1/5/2022 12:58:49 AM. by Misato Katsuragi. Forum started by Padmanaban
7309
Modular Kitchen
Last answer on 11/30/2021 12:56:09 AM. by axelbach. Forum started by Veena Gil
2926
Kitchen Sink
Last answer on 11/30/2021 12:21:26 AM. by Anjleen. Forum started by Sasikala R
2490
Introduction
Last answer on 10/23/2021 8:23:11 AM. by S L Gupta (Civil Engg). Forum started by davidraju
3661
Small Space Kitchen
Last answer on 9/15/2021 5:01:17 AM. by KVSN RAJU. Forum started by Shital Miriyala
2662
Thank you for all you do
Last answer on 7/19/2021 5:14:13 AM. by Amit Hasija. Forum started by raghav
2872
Kitchen Design Ideas
Last answer on 5/18/2021 7:44:04 PM. by rafi. Forum started by b.arunaseshan
2550
'island' counter in kitchen
Last answer on 1/2/2021 5:27:46 AM. by S L Gupta (Civil Engg). Forum started by Shashi Panwar
Kitchen Door
Last answer on 1/2/2021 5:22:53 AM. by S L Gupta (Civil Engg). Forum started by K. Basu
2539
Last answer on 1/2/2021 5:22:28 AM. Forum started by batambuze abdu
3348
Last answer on 12/31/2020 2:45:52 AM. by juhi. Forum started by ruchika jain
2625
How much would be the approximate cost of setting up a kitchen like this?
Last answer on 12/31/2020 2:40:21 AM. by ranjeetsaini. Forum started by debashish
3952
Last answer on 10/11/2020 7:21:30 AM. by S L Gupta (Civil Engg). Forum started by maruthi prasad
3285
Kitchen modular size 8*8 fit
Last answer on 10/11/2020 7:13:57 AM. by JAI PRAKASH. Forum started by Hitendra singh bhadoria
Kitchen Lighting
Lighting in kitchen is very crucial to make cooking experience a pleasure. A bright kitchen also adds to the warmth an..
Tips for Lighting your Kitchen
Lighting plays an important role in setting the ambience of the room. Consider the amount of available light when your c
Home Lighting Tips
Lighting arrangements in a home needs careful planning. It should be according to requirements like task lighting for ..
Tips for Kitchen Lighting
Kitchen is a place where a lady spends her maximum time so it should have comfortable and fresh feeling. Today's kitch..
The kitchen redesign is a fantastic initiative to ensure the health of family members. It needs fresh and vigilant con..
Kitchen Decoration
Make your kitchen both friendly and well-organized with these creative decorating ideas. Kitchen is a one of the most ..
Lights,
Lights, Design & Action
Light not only illuminates but define one’s path. It can change mood, hide or highlight an object, kill or liven up a ..
Kitchen Accessories
Kitchen Remodeling Ideas
Kitchen Backsplash
