Home -> Forums -> Construction -> Layout and House Plans -> LAY OUT AND COST
LAY OUT AND COST
Wed Jan 09, 2013Total posts : 2
MANSAP1
MANSAP1
Topic: LAY OUT AND COST
I have a plot in north east delhi witch measure 25.4*47.9 (1215sq feeet] I want to contruct it three story(ground , first and second floor) at ground floor I want to leave space for parking in such a way that  a small car like swift can be round back in parking area . Any suggestion regarding layout and cost I want its urgent please help  me.
Thu Jan 10, 2013Post  #1
sonigupta
sonigupta
Post subject: suggestion regarding layout and cost
Thu Jan 10, 2013Post  #2
Dear Mansapi
          The cost of the building depends upon the plan and elevation of the building and specification used in the construction.
However there are two option at gharexpert .com one is estimator tool for cost calculation and second is detail estimate link is given below.
http://www.gharexpert.com/Estimator/Startpage.aspx
When you are constructing your sweet home, you will face many difficulties. To overcome these difficulties, gharexpert.com website solve the prblems, if you have time to read the different articles about construction, vastu, interior etc. There is lot of materials in this website, for some articles link is given below.
http://www.gharexpert.com/articles/Start-Construction-1528/Guidelines-while-Starting-Construction_0.aspx
.gharexpert.com/home/new_categorylist.aspx?PL=2&CATID=1326
http://www.gharexpert.com/articles/Start-Construction-1460/Purchasing-Guidelines-Cement-Bricks-_0.aspx
Tue Jan 08, 2013
2622
4903
How much it cost for laying a foundation for a 30x40 site upto 7ft deep and plin
Last answer on 5/4/2013 2:20:44 PM. by nithun. Forum started by nithun
4836
1707
What are the important steps of maintenance after installation of blended marble vinyl flooring?
Last answer on 6/25/2014 1:43:17 PM. by S L Gupta (Civil Engg). Forum started by chandrapalsen
2195
can sewerage line be lying in south west corner of house
Last answer on 3/28/2012 11:42:26 PM. by Priyanka Sharma. Forum started by vkgogra
1942
Last answer on 5/24/2012 5:08:53 PM. by S L Gupta (Civil Engg). Forum started by gaju
2052
1487
Lay out Plan details
Last answer on 8/10/2016 3:13:39 PM. by Beenu Phogat. Forum started by Arun Kumar
2829
1826
2353
laying of roof
2125
CRACK IN CENTRE OF SLAB
3134
false ceiling
1617
suggest layout 36fit by 60 fit
Last answer on 5/29/2015 10:34:14 AM. by seema tyagi. Forum started by Ashish
1553
I want to buy a piece of land What could be are of land required for house in 35
Last answer on 9/4/2017 12:20:24 AM. by S L Gupta (Civil Engg). Forum started by Shailendra Srivastava
1525
1751
Plot size 12 by 60 feet
Last answer on 11/20/2016 11:55:01 PM. by Beenu Phogat. Forum started by Rahul
3087
2561
dear expert please give me lay out plan of north facing construction for 30*25ft
Last answer on 4/17/2012 5:50:14 PM. by manish. Forum started by manish
2691
2924
2188
2184
2793
4520
1890
2284
2266
2766
3464
2356
1967
2242
3595
2324
2091
2792
1548
2114
Guideline for laying DPC
Check width and depth of the channel, the quality and size of the bricks for mechanical protection.Whether cable ident..
